Re: Spark plug heat range
[Re: Sniper]
#2929873
06/03/21 08:09 PM
06/03/21 08:09 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Running a bit rich, heat range looks ok by the appearance of the ground strap It's rich because I just start it up and don't run the car much. I need to get it up to speed and heat more often. It's tough to get tge car out. It's always buried. Keeps fouling plugs.
[Re: Sammy]
#2929919
06/03/21 09:58 PM
06/03/21 09:58 PM
Posts: 6,220 nowhere
Sniper
nowhere
Running a bit rich, heat range looks ok by the appearance of the ground strap It's rich because I just start it up and don't run the car much. I need to get it up to speed and heat more often. It's tough to get tge car out. It's always buried. Keeps fouling plugs. If this is the case then looking at the plugs isn't going to help. Sounds like you know what needs doing, drive it more.
[Re: Sniper]
#2930385
06/05/21 08:17 PM
06/05/21 08:17 PM
Posts: 15,279 Omaha Ne
TJP
Omaha Ne
Running a bit rich, heat range looks ok by the appearance of the ground strap It's rich because I just start it up and don't run the car much. I need to get it up to speed and heat more often. It's tough to get tge car out. It's always buried. Keeps fouling plugs. If this is the case then looking at the plugs isn't going to help. Sounds like you know what needs doing, drive it more. 100%
