Re: 318 build
[Re: scratchnfotraction]
#2941930
07/10/21 10:22 PM
07/10/21 10:22 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
[quote=scratchnfotraction]thanks Larry, yes you would be correct on the rod & main bearings.
I am sentimental about the intake as I got it from Larry Green AKA 340shorty a few days before he passed away. since it is a Holley intake only fitting it have a Holley carb.
Larry was one of the good ones, miss that guy.
1981 Dodge D150 360 auto
Re: 318 build
[Re: redraptor]
#2951348
08/07/21 11:50 AM
08/07/21 11:50 AM
Posts: 15,855 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
It's important to stay hydrated while engine building! Yes! Hydrate until a good buzz comes on and then pause for at least 10 minutes I'm waiting on call back from engine builder :("Next week" has been a month from two of them but I'm being patient. I'm pretty sure of one I want to go with but I guess he's real busy so I'm giving him time. He seems like a really good guy and straight forward
Facts are stubborn things.
Re: 318 build
[Re: larrymopar360]
#2989645
11/27/21 05:34 PM
11/27/21 05:34 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Scratchn' making progress with some NOS goodies
Re: 318 build
[Re: larrymopar360]
#2989694
11/27/21 08:52 PM
11/27/21 08:52 PM
Posts: 9,454 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Might look where the oil hole is on those lifters are, a big bunch of clackers got superseded with the oil hole in a diff place so they would not drain when sitting.
STOP POTATO HATE!
Re: 318 build
[Re: redraptor]
#2989824
11/28/21 12:44 PM
11/28/21 12:44 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Yes Mike's magic shed contains lots of Mopar goodies!!! I accidentally left out NOS valve cover gaskets too. I like the old style breather he's using too.
Re: 318 build
[Re: Mr PotatoHead]
#2990088
11/29/21 09:56 AM
11/29/21 09:56 AM
Posts: 15,487 Florida
scratchnfotraction
Might look where the oil hole is on those lifters are, a big bunch of clackers got superseded with the oil hole in a diff place so they would not drain when sitting. IIRC-that is when they change the early lifter from a non-oil through lifter/solid PRs to a oil through lifter/solid PRs and later on to a oil-through lifter hollow 5/16" PRs in the later 90-91 pre-magnum LA roller cam engines as they gear up for the 92-93 magnum engine debuted. you have to WATCH for non oil through lifters going into a magnum engine that oil rockers via PRs I have also found in a lot of the 90-91 pre-magnum LA roller 5.2 engines that they oiled through the heads/shafts as well as up through the lifters/PRs. IMHO this is why a lot of them had VC leaks as it is a lot of oil in the VC area at operating speeds & that the PCV valve suck a lot of oil as well. (why I use a cheap oil/air separator on mine) on the police engines they have grooved #2 & #4 cam bearings for full time oiling to rockers and they tend to have a lot of VC leaks also. I install restrictors in the block reducing the feed to rocker to 1/2 the oem block size. along with all the oiling mods I do. all of my lifters are the same part # & yr, they are sealed NOS-1989 OEM replacements- oil through lifter/solid 5/16" PRs. I index them when installed hole facing cam per FSM book. installed dry/not pumped up and all PRs where at zero lash/no preload per cyls. = I could pre load bottom out each lifter by hand with no loose rockers. then primed oil pump/engine - Lucus sae30 break in oil with 65 psi with a 1/2" drill. they all pump up and primed till no air bleeding out of lifters. rotating engine to oil both sides all 16 rocker oiling. all on a HughesEngines roller cam 192*/203* .500/.513 lift 114* LSA I should be good to go.
