fresh 440 oil pressure drop #2929463
06/02/21 12:30 PM
06/02/21 12:30 PM
Hangtowner Offline OP
I have 700 miles on the rebuild of a 440. Oil pressure has been fine at about 60/65 on the highway. Yesterday was a 100 degree day. Water temp was 3/4 on the gage up from the usual 1/2 way point. I could see the oil pressure drop as the temp went up. It went to 45 at 70mph. Idle was still around 15. I use 20/50 VR1. I think this is a bearing clearance issue and no change to the pressure relief valve setting will really alter things, right?
Re: fresh 440 oil pressure drop [Re: Hangtowner] #2929591
06/02/21 07:03 PM
06/02/21 07:03 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I assume you were turning the engine well below 4500 RPM, 10 pounds per thousand RPM is considered fine oil pressure.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: fresh 440 oil pressure drop [Re: Hangtowner] #2929599
06/02/21 07:15 PM
06/02/21 07:15 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Your engine was running significantly hotter. So the oil is thinner - and the pressure drops. I'll bet there is nothing wrong with it other than a marginal cooling system. Do you have a temperature gauge that is calibrated?
Best way to verify this is "normal behavior" is to see if the pressure is back where it was on a cooler day...
Could also cut open your oil filter and look for metal.
Re: fresh 440 oil pressure drop [Re: DrCharles] #2929626
06/02/21 08:44 PM
06/02/21 08:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree whistling beer
Re: fresh 440 oil pressure drop [Re: Hangtowner] #2929763
06/03/21 12:55 PM
06/03/21 12:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Right; you have a volume issue, not a pressure issue. Was a standard volume pump installed?
