? nos tan distributor caps for V-8's look like ? #292926
04/19/09 03:12 PM
04/19/09 03:12 PM
New Jersey
conteycp Offline OP
conteycp  Offline OP
New Jersey
I am trying to determine if I have purchased a original V-8 distributor cap for my 1971 383 engine . Does anyone know what markings to look for ?
The cap I just purchased has a small round recessed circle on it that says made in the usa on top . At the base on the edge where the cap sits on the distributor is the number 16
Re: ? nos tan distributor caps for V-8's look like ? [Re: conteycp] #292927
04/19/09 07:13 PM
04/19/09 07:13 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
single or dual point dist ?
Re: ? nos tan distributor caps for V-8's look like ? [Re: gtx6970] #292928
04/20/09 12:29 PM
04/20/09 12:29 PM
New Jersey
conteycp Offline OP
conteycp  Offline OP
New Jersey
single point ,,, no dual points for 383 in 71
Re: ? nos tan distributor caps for V-8's look like ? [Re: conteycp] #292929
04/20/09 01:32 PM
04/20/09 01:32 PM
It's a dry heat
It's a dry heat
OE #2444507
Originals were tan, and blank with no outward visible markings of any kind
with the pt number cast on the inside.
Later replacements have the 'rotation' on the top of the cap. even later replacements have a vent on the top of the cap between the towers -technically both are wrong.
I have them both ways if you want comparison pics
Re: ? nos tan distributor caps for V-8's look like ? [Re: gtx6970] #292930
04/20/09 08:21 PM
04/20/09 08:21 PM
New Jersey
conteycp Offline OP
conteycp  Offline OP
New Jersey
if you have a pic of the original I would like to see it thanks
Re: ? nos tan distributor caps for V-8's look like ? [Re: conteycp] #292931
04/20/09 10:04 PM
04/20/09 10:04 PM
It's a dry heat
It's a dry heat
Click on the attachements for a bigger view.
Original on the right in all pics, later issue on the left. With exception to the lettering on top they are the same in color and appearence and dimensions.
Both have the same part number - 2444507 cast on the inside ribbing
Re: ? nos tan distributor caps for V-8's look like ? [Re: gtx6970] #292932
04/20/09 10:04 PM
04/20/09 10:04 PM
It's a dry heat
It's a dry heat
2
Re: ? nos tan distributor caps for V-8's look like ? [Re: gtx6970] #292933
04/20/09 10:05 PM
04/20/09 10:05 PM
It's a dry heat
It's a dry heat
3
Re: ? nos tan distributor caps for V-8's look like ? [Re: gtx6970] #292934
04/20/09 10:06 PM
04/20/09 10:06 PM
It's a dry heat
It's a dry heat
last one
Re: ? nos tan distributor caps for V-8's look like ? [Re: gtx6970] #292935
04/22/09 08:44 AM
04/22/09 08:44 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
