Page 4 of 4 1 2 3 4
Re: 572 B1 org Part 1-Buying Parts [Re: JERICOGTX] #2978837
10/27/21 09:29 AM
10/27/21 09:29 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Originally Posted by JERICOGTX
Are you planning on running a vacuum pump on this engine?
Not planning to. I am putting some provisions for that, like valve covers with AN12 fittings.
But the first year will not have a vacuum pump. This is not a fancy motor, no dry sump either.
One had the AN12 o-ring boss when I got them; it will use the screw-in fitting.
The other I had welded a AN12 male fitting to the top.
These have spray bars (when I got them), but I plan to only use pushrod oiling.
Re: 572 B1 org Part 1-Buying Parts [Re: 440Jim] #3085459
10/12/22 01:13 PM
10/12/22 01:13 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Post to include link to Part 2 - Component Observations
Click this link for 572 B1 org - Part 2
Page 4 of 4 1 2 3 4
