Trans experts needed #2929027
05/31/21 10:40 PM
05/31/21 10:40 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
2001 Ram Van 360 auto, trans didn’t seem to be shifting right, quick into second with a slight back drag. So I adjusted the kick down cable to up the pressure. Now a little better in second but I have to lift to go into third and overdrive, adjusted the cable 3 so far trying to get back to original place, close but still early shift into second. About 30,000 miles on total rebuild and new vert.
Any ideas?
Re: Trans experts needed [Re: cudaman1969] #2929106
06/01/21 10:07 AM
06/01/21 10:07 AM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
back then dad worked for a mopar dealer. they had a lot of that. they called it "lift foot syndrome". had to let off gas pedal to shift. tsb about drum and piston problem. tsb gave new part number for piston and drum he said if he remembers right. john k. should be along soon.
Re: Trans experts needed [Re: trw1982] #2929117
06/01/21 10:23 AM
06/01/21 10:23 AM
fredericksburg,va
fredericksburg,va
Re: Trans experts needed [Re: cudaman1969] #2930864
06/07/21 12:51 PM
06/07/21 12:51 PM
fredericksburg,va
fredericksburg,va
Simple fix! MY MISTAKE. The three screws on the TCC and 3-4 solenoid pack were not even finger tight, been like that for 30 thousand miles. When I did the valve body, trans overhaul I just overlooked tighting them. The engine light codes, erratic shifting all went back to three loose screws! Double check everything from now on!
Re: Trans experts needed [Re: cudaman1969] #2931229
06/08/21 11:59 AM
06/08/21 11:59 AM
moparx Offline
moparx  Offline
good to know it was a simple fix ! up
however, finding things like this has a tendency to "thin" one's hair on the top. biggrin
beer
Re: Trans experts needed [Re: moparx] #2931436
06/08/21 08:17 PM
06/08/21 08:17 PM
fredericksburg,va
fredericksburg,va
Not sure it’s fixed, light came on again coming home from work, I’ll look later, too hot. All that time leaking might have messed up something inside
