70 Challenger vinyl console replacement #2928992
05/31/21 07:58 PM
05/31/21 07:58 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
I am getting ready to replace the vinyl decals on my center console and door inserts on my 70 Challenger Vert.
Is it better to go over the top of existing or remove the old vinyl?
What is the best way to remove the old vinyl if that is best?
Re: 70 Challenger vinyl console replacement [Re: 70VERT] #2929129
06/01/21 11:06 AM
06/01/21 11:06 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Remove the original vinyl first. I had good luck removing the old vinyl with a small steam cleaner. Others have had good results with a Goo-Gone type product.
Re: 70 Challenger vinyl console replacement [Re: 70VERT] #2929230
06/01/21 04:25 PM
06/01/21 04:25 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
heat gun sure helps.. or hot hair dryer
Re: 70 Challenger vinyl console replacement [Re: ph23vo] #2930026
06/04/21 11:19 AM
06/04/21 11:19 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Razor blade and Goo Gone, just like any sticker.
