Re: The rubber hose trick on the distributor
[Re: CrAlt]
#29342
09/04/06 08:17 PM
09/04/06 08:17 PM
Posts: 903 Saskatchewan, Canada
cudabin
Wow !! I just put a 1/2 collar clamp on and the timing is now Rock steady !!! I tightned the 2 allen screws up pretty good, so do i need to re-do it and use loctite ??? Thanks for the tip! Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Post deleted by Defbob
[Re: cudabin]
#29343
09/04/06 09:37 PM
09/04/06 09:37 PM
[Re: 340727dart]
#29345
09/05/06 03:31 PM
09/05/06 03:31 PM
Posts: 4,867 Upstate, NY
MikeP
Upstate, NY
The SB drive is on the other side of the cam, the rotation of the cam is pushing it down already.
If the tang on the bottom of your dist. does not fit tightly in the drive slot that slop could cause your timing to move back and forth a bit. If it's quite a bit you can weld a small bead on the end of the shaft and the grind it back down untill it fits perfect or if the slop is not much I have just peened the corners of the tang with a few raps with a hammer (carefully) and it has gotten the job done.
I put the collar on my 340's distributor this evening and just got back from driving it. The engine idles smoother now, which kind of surprised me. I didn't know what to expect by putting it on. But, it seems like the $2.69 I spent for the collar was money well spent.
If this is true on LA's, then is it the weight of the collar(I have three different ones weighing 31-42gms) giving additional inertia to the shaft and giving the tang positive placement in the slot?
"Think Pink" 67'Dart GT vert, 69' Newport vert, 67' Barracuda
and a pile of trucks 78'79'91'92 CTD
#29349
09/05/06 04:45 PM
09/05/06 04:45 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I'm glad everyone's having positive results, my gear must have been moving up and down pretty good cuz setting timing is a breeze now. I did loctite mine before tightening the screws real good, just some added insurance. No problem Sunroof, I'll bring my wheelie bars over for you. Sure hope Fran's not reading all this. I don't think the weight of the collar will matter, although I'd run the lightest one for rotating mass.
[Re: ProSport]
#29350
09/05/06 09:47 PM
09/05/06 09:47 PM
i talked to a friend this past weekend that told me he has run one on all his small blocks for years now, he got his from hambuger years ago. im installing mine this week to test on friday at norwalk Great post ProSport thanks for all the info from everyone. Bondobob
#29351
09/05/06 09:49 PM
09/05/06 09:49 PM
Posts: 5,618 long island NY
Ari440
long island NY
are you guys instaling one or two clamp collars ?
1.39 9.85 - 137 mph
[Re: Ari440]
#29352
09/05/06 09:56 PM
09/05/06 09:56 PM
I got one like Duster Dave got. Mc Master (562) 463-4277 #9947K16 extra wide 1pc. clamp on collar 1/2 bore-1 1/8 OD. - 7/8 wide double set screw lock cost $8.31 i picked it up at my local tool dealer that handles Mcmaster-Carr products. Bondobob
#29353
09/06/06 02:20 PM
09/06/06 02:20 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I just picked up two clamps from Granger , they were like 2.60 apiece. After seeing All of the positive results I felt I needed them. As my Timing is all over the place above 3500 RPM. Thanks for the post Prosport., mike
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
[Re: 66coronet]
#29355
09/06/06 03:43 PM
09/06/06 03:43 PM
#29356
09/06/06 03:52 PM
09/06/06 03:52 PM
ProSport
Akron, Ohio
I doubt I'll run any quicker with this trick, it's just a whole lot easier to set timing. We'll find out Saturday if it doesn't rain.
