Brake fluids, which type for street and strip? #2918034
05/03/21 02:02 PM
05/03/21 02:02 PM
Cab_Burge Offline OP
I'm confused on which type, 3,4, or 5 brake fluid to use on my street and strip cars help
I've heard and seen comments to NOT use type 5 on these cars, I'm wondering why confused
All help appreciated up
Re: Brake fluids, which type for street and strip? [Re: Cab_Burge] #2918049
05/03/21 02:40 PM
05/03/21 02:40 PM
Kirkland, Washington
Pacnorthcuda Offline
I use 4 on everything, it’s compatible with 3, and has a higher boiling point. Don’t have to consider the DOT 5 considerations.
Re: Brake fluids, which type for street and strip? [Re: Pacnorthcuda] #2918151
05/03/21 07:20 PM
05/03/21 07:20 PM
AndyF Offline
AndyF  Offline
Same here, I use Dot 4 in my cars. It is what most OEM cars use now.
Re: Brake fluids, which type for street and strip? [Re: Cab_Burge] #2924973
05/20/21 06:45 PM
05/20/21 06:45 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I started using DOT5 well over 25 years ago. Primarily to save the paint on my restorations. I always get the stuff all over everything. DOT 5 does not hurt the paint, and I have certainly got enough of it on the paint to know. I have never had any problems out of 5 and I use it in all my old Mopars. But if the problems with paint on the 3 and 4 isn't an issue for you, then there is no real reason to due the changeover, in my opinion.
Master, again and still
Re: Brake fluids, which type for street and strip? [Re: DaveRS23] #2926611
05/25/21 07:14 PM
05/25/21 07:14 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
If it's a real track car, then check out DOT5.1 fluid. We use Motul brand in our endurance racing track car. Basically, the higher the number, the higher the boiling point. DOT is silicone based, but DOT5.1 is the same chemical type as DOT3 and 4, so you can mix them if you wish.
Re: Brake fluids, which type for street and strip? [Re: AndyF] #2926715
05/25/21 11:43 PM
05/25/21 11:43 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I agree iagree
Re: Brake fluids, which type for street and strip? [Re: autoxcuda] #2926774
05/26/21 09:22 AM
05/26/21 09:22 AM
KY
9
95Kota408 Offline
95Kota408  Offline
KY
I have heard that using synthetic brake fluid in systems that don't require it might be harmful to the rubber seals inside the system. Any truth to that? I recently had a master cylinder cap with the rubber expanded so much I could barely get the cap on the master cylinder. I flushed the system and replaced the master cylinder and put DOT 3 back in out of precaution since I wasn't sure if what I heard was true. This was in a 99 Durango 5.9L
Re: Brake fluids, which type for street and strip? [Re: 375inStroke] #2927128
05/26/21 11:37 PM
05/26/21 11:37 PM
This a drag race car that will be ran at our local 1/8 mile track to see if the owner likes drag racing or not. It might run 120.+ MPH in the 1/8, we will see luck
I do not know anything about that motor, I may offer to make 1 or 2 passes in the car to make sure it goes straight and stops before advising him to go WOT in it work
I will suggest that he tries a couple of part throttle launches and lifting at half track and go from there. If he likes it and wants to go for it I'll advise him to foot brake launching it at different RPM before switching to trans brake launching it later at WOT luck twocents
