Re: CopperKote antisieze on spark plug threads ?
[Re: WedgeFED]
#2926639
05/25/21 08:37 PM
05/25/21 08:37 PM
Posts: 12,814 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
This subject gets beat to death. Been a mechanic for well over 30 years. Never and I repeat Never has even one manufacturer ever used lube of any sort on any spark plug thread ever... I think there may be more than a few phord owners who wished that phord had used something on their spark plugs.
Master, again and still
[Re: DaveRS23]
#2926644
05/25/21 08:47 PM
05/25/21 08:47 PM
Posts: 2,541 PA
moparacer
PA
This subject gets beat to death. Been a mechanic for well over 30 years. Never and I repeat Never has even one manufacturer ever used lube of any sort on any spark plug thread ever... I think there may be more than a few phord owners who wished that phord had used something on their spark plugs. That was the idiots who thought 2 or 3 threads were plenty to hold a spark plug in....
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#2926697
05/25/21 11:00 PM
05/25/21 11:00 PM
Posts: 43,744 Bend,OR USA
Cab_Burge
This subject gets beat to death. Been a mechanic for well over 30 years. Never and I repeat Never has even one manufacturer ever used lube of any sort on any spark plug thread ever... I think there may be more than a few phord owners who wished that phord had used something on their spark plugs. That was the idiots who thought 2 or 3 threads were plenty to hold a spark plug in.... Ford Engineering at their best :whistling :
[Re: DaveRS23]
#2926756
05/26/21 07:51 AM
05/26/21 07:51 AM
Posts: 4,882 Florida
BDW
This subject gets beat to death. Been a mechanic for well over 30 years. Never and I repeat Never has even one manufacturer ever used lube of any sort on any spark plug thread ever... I think there may be more than a few phord owners who wished that phord had used something on their spark plugs. Yep, carbon build up on threads and crappy Autolite 2-piece plugs. PIA changing those, lucky to see chatter on Mustang forum, only broke 2, and that was after only 30k. Nickel high temp on everything now.
[Re: WedgeFED]
#2927230
05/27/21 12:55 PM
05/27/21 12:55 PM
Posts: 23,295 Here
jcc
Here
This subject gets beat to death. Been a mechanic for well over 30 years. Never and I repeat Never has even one manufacturer ever used lube of any sort on any spark plug thread ever... Neither has my ex wife, I suspect because she never had to change a set of platinum plugs after 100,000 miles or cared.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: 6PakBee]
#2927232
05/27/21 12:59 PM
05/27/21 12:59 PM
Posts: 23,295 Here
jcc
Here
So if you are an idiot and over torque your spark plugs you will have problems. ................. Hmm. Think I'll keep using the nickel anti-seize. Not the way I would phrase it, but I agree with your sentiment. Find it hard to believe copper can corrode more or enough relatively, to reduce conductivity in this environment.
[Re: A/MP]
#2927840
05/28/21 07:28 PM
05/28/21 07:28 PM
Posts: 1,902 MYRTLE BEACH SOUTH CAROLINA
ek3
aluminum's number 1 anti corrosive agent is zinc. long term heating up and cooling down cycles can put moisture in the threads area = oxidation . if you are worried about it , use zinc chromates on the threads . i am pretty sure most [not all] come with a coating on them anyhow..
[Re: ek3]
#2927901
05/28/21 10:25 PM
05/28/21 10:25 PM
Posts: 16,640 On the run…
BloFish
On the run…
aluminum's number 1 anti corrosive agent is zinc. long term heating up and cooling down cycles can put moisture in the threads area = oxidation . if you are worried about it , use zinc chromates on the threads . i am pretty sure most [not all] come with a coating on them anyhow.. Exactly.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: ek3]
#2927976
05/29/21 08:44 AM
05/29/21 08:44 AM
Posts: 23,295 Here
jcc
Here
aluminum's number 1 anti corrosive agent is zinc. long term heating up and cooling down cycles can put moisture in the threads area = oxidation . if you are worried about it , use zinc chromates on the threads . i am pretty sure most [not all] come with a coating on them anyhow.. Oxidation of alum is almost unpreventable. Actually one of Alum best attributes is the hardness/toughness of the normal oxidised alum surface. I believe what is the issue here is one of the combustion by products of every power stroke, among other things, is H2O, albeit its at very high temps, but nevertheless, it is still present. And I also suspect under the pressures the plug endures, some, even a minute amount, will find some H2O forced into the threads, where it will eventually condense. Electrolysis requires moisture, and a steel spark plug and an alum head are good candidates for electrolytic corrosion, and will overcome the alum oxide layer noted above. I also suspect the anti seize mainly fills the microscopic gaps in the thread interface, reducing the area electrolysis can occur easily and any space for any water to accumulate. Any OEM plug plated coating of the plug that reduces the electrical electrolysis potential between the two items has to be a plus. Ok, maybe not a diamond, but its shiny.
[Re: justinp61]
#2928105
05/29/21 01:35 PM
05/29/21 01:35 PM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have worked at several new car dealers and have seen every OE used brand seize installed in the factory (assumedly to factory recommendations) in the threads if left in too long, Champion, Bosche, NGK, Denso... The anti seize not only provides lube when its time to remove it it also fills the voids to keep those combustion byproducts out, I have never pulled a spark plug with anti seize on it that was seized in the hole.
