Re: Would/do you use a spread bore carb?
[Re: Guitar Jones]
#2926079
05/24/21 09:55 AM
05/24/21 09:55 AM
Posts: 12,108 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
As for vacuum secondaries, I have never found a need for anything other than vacuum secondaries on the street. If you are considering the street demon it only comes with those. You may have 'never found a need for anything other than vacuum secondaries on the street', but our favorite manufacturer (Mopar) used mechanical secondaries more than anything else. Only the later Holleys used vacuum. ALL of the Carters (AFBs, AVSs, Thermoquads) used mechanical secondaries. And that was on everything from 273s to Hemis. Not totally accurate, while it's true the actual throttle butterflies were mechanically actuated, the air door in the top prevented them from actually doing anything until that air valve opened as the engines ability to ingest the extra air and fuel increased creating the same effect as a Holley type of vacuum actuated carb. So TQs, QJs, AFBs and AVSs are really considered to be vacuum secondary carbs as the secondaries only work as the engine demands and not the throttle. Not totally accurate. The secondary air door has an impact on air flow only IF they are adjusted a certain way. While we all understand the function of the secondary air doors (well, maybe some do and some don't) this is the first time I have heard anyone describe the Carters as vacuum secondary carbs. There are a few AFBs that actually used a vacuum pod to operate the secondaries and there are AFBs without secondary air doors.Twist it any way you want to make an argument, but the secondary throttle plates are opened by direct linkage from the primaries (for the vast majority of Carters) and the air doors are above the boosters on most models so that they are as much an enrichment device as they are an air flow control device. The air doors have an impact on the secondaries' operation, but they do not control them. Primary control rests with the linkage and linkage alone. Mopar's Carters were not vacuum secondary carbs.
Master, again and still
[Re: DaveRS23]
#2926294
05/24/21 09:04 PM
05/24/21 09:04 PM
Guitar Jones
I said they are considered vacuum secondary carbs because the secondaries function off of engine demand and not strictly off of the throttle plate butterflies. Twist however you want but look them up on Summit or Jegs and see if they are listed as mechanical or vacuum secondary carbs. You could also try pointing out where the secondary accelerator pump squirters are on those carbs.
[Re: moparx]
#2926312
05/24/21 10:45 PM
05/24/21 10:45 PM
Posts: 621 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
just love those thermoquads ! i have always wanted to try a tunnel ram with twin thermoquads, but have never had the opportunity to do so. You mean like this ?
[Re: Guitar Jones]
#2926405
05/25/21 09:27 AM
05/25/21 09:27 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I said they are considered vacuum secondary carbs because the secondaries function off of engine demand and not strictly off of the throttle plate butterflies. Twist however you want but look them up on Summit or Jegs and see if they are listed as mechanical or vacuum secondary carbs. You could also try pointing out where the secondary accelerator pump squirters are on those carbs. So you use sales ads for your technical information? That helps explain your opinion on this. And I have no idea what you are trying to say about the pump squirters. Did you read that in an advertisement, too? Bottom line; the secondary air door is not essential to the operation of the secondaries. It can be an asset and certainly helps in some applications but is not an absolute necessity.
[Re: DaveRS23]
#2926628
05/25/21 08:13 PM
05/25/21 08:13 PM
Posts: 6,267 nowhere
Sniper
nowhere
I said they are considered vacuum secondary carbs because the secondaries function off of engine demand and not strictly off of the throttle plate butterflies. Twist however you want but look them up on Summit or Jegs and see if they are listed as mechanical or vacuum secondary carbs. You could also try pointing out where the secondary accelerator pump squirters are on those carbs. So you use sales ads for your technical information? That helps explain your opinion on this. And I have no idea what you are trying to say about the pump squirters. Did you read that in an advertisement, too? Bottom line; the secondary air door is not essential to the operation of the secondaries. It can be an asset and certainly helps in some applications but is not an absolute necessity. Straight out of the Carter manual for the TQ
[Re: Sniper]
#2926637
05/25/21 08:32 PM
05/25/21 08:32 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Mechanical secondaries with a variable venturi feature. Good points, straight from Carter and not from a sales brochure.
Venturi: A Venturi is a system for speeding the flow of the fluid, by constricting it in a cone shaped tube. In the restriction the fluid must increase its velocity reducing its pressure and producing a partial vacuum. As the fluid leaves the constriction, its pressure increases back to the ambient or pipe level.
A venturi DOES NOT control the secondary operation. It aids it.
Thank you.
[Re: Hangtowner]
#2928625
05/30/21 07:43 PM
05/30/21 07:43 PM
Posts: 15,887 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I wish I knew of a chassis dyno here in town. I guess it's possible there's one I don't know of but never heard of one and we're not that big. Also isn't a street demon a Holley? I guess he meant same design not "owned by".
Facts are stubborn things.
[Re: larrymopar360]
#2928695
05/30/21 09:47 PM
05/30/21 09:47 PM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Larry,
If you score a 9800 series TQ I will set it up for you. The attached electric choke takes care of running this beast with any intake you chose.
Anyways, they are out there, I see them occasionally pop up on eBag...not too often, but they can be found.
[Re: Diplomat360]
#2928751
05/31/21 02:41 AM
05/31/21 02:41 AM
Posts: 608 TN
1DGEMAN
TN
Larry,
Anyways, they are out there, I see them occasionally pop up on eBag...not too often, but they can be found. I have a 9801and a 9811
Real Men shift for themselves
[Re: DaveRS23]
#2928772
05/31/21 08:20 AM
05/31/21 08:20 AM
Guitar Jones
Thank you. Read the first and second sentence in snipers attachment again. That is what I'm saying. You can't open those secondaries mechanically without some sort of restriction to delay the intake of additional air or you need a secondary accelerator pump shot to prevent a huge backfire and most likely stalling the engine. In other words, vacuum secondary carbs allow the intake of extra air and fuel as the engine demands it, not as a function of the mechanical linkage alone. Block that secondary air valve fully open and then tell us how those mechanical secondaries work. I don't know why you want to argue this point, it's really useless and unproductive, so whatever, I'm done.
[Re: Hangtowner]
#2929197
06/01/21 03:12 PM
06/01/21 03:12 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Holley owns Demon now, but the only thing in common is the secondary jets. I was just about to ask that. One thing I really like about the new design factors of Demon are the large bowls helping with starts after sitting for several days. Damn 10% ethanol. I get about three days parked and after that have to pour gas down carb. Would rather not have to install another pump.
[Re: larrymopar360]
#2929321
06/01/21 09:16 PM
06/01/21 09:16 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
One MAJOR improvement over the Thermoquads is that there is no gasket at the bottom of the fuel bowl.
