1974 Roadrunner Grill mounting plastic clips #2925858
05/23/21 02:55 PM
05/23/21 02:55 PM
Buzzardbreath Wyoming
BigBird Offline OP
BigBird  Offline OP
Does anyone sell the round plastic clips that the grill screws screw into on a 74 Roadrunner/Sattelite? They go into the header panel between the grill and hood. I believe they are the same type the headlight bezels screw into as well.
Re: 1974 Roadrunner Grill mounting plastic clips [Re: BigBird] #2925920
05/23/21 07:07 PM
05/23/21 07:07 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
This place has something real close. I can't find the part number I used that just made it.
Anyways, we're in the right church, just need to find the correct pew
http://retro-motive.com/nylon-spacer-nuts-headlight-bezel-trim-grille-etc-1-4-long-qty-8-1761/
Common sense is a flower that does not grow in everybody's garden
Re: 1974 Roadrunner Grill mounting plastic clips [Re: Ron_M] #2925965
05/23/21 08:22 PM
05/23/21 08:22 PM
BigBird Offline OP
BigBird  Offline OP
Those look right. I'll check into them. Thanks
