W2 stroker build - cylinder wall thickness check please #2925562
05/22/21 03:49 PM
05/22/21 03:49 PM
Windsor, ON, Canada
Diplomat360 Offline OP
Windsor, ON, Canada
Guys,
Take a look please at the attached cylinder wall thickness check results.
I have never done this before, so no idea what ballpark figure is good and what's bad. This is a street/strip ride, looking to get 500hp out of that combo. I did this at home, using a hobby shop (aka 'made in China') checker, but tried it out first on a few known pieces of materials and the thickness readout was correct.
Block (1974 casting# 4006830-360-1, 360) has been machined already, it's 0.030" over, so this is a bit of an "after the fact" thing...LOL, part of my "learning to blueprint" class if you will. The only weird thing I spotted is #2 BACK reading of .650", but I went over it a couple of times and got the same reading, so maybe just a thick piece of casting?
Besides that, the THRUST side seems to be all thicker than 0.300" with a couple of low 0.295 and 0.287 readings on #1.
As always, appreciate all feedback.
Thanks!
408W2 - Block Cylinder Wall Sonic Test - DRIVER - IMPERIAL.jpg408W2 - Block Cylinder Wall Sonic Test - PASS - IMPERIAL.jpg
Last edited by Diplomat360; 05/22/21 04:46 PM. Reason: Included the block year and casting #
Re: W2 stroker build - cylinder wall thickness check please [Re: Diplomat360] #2925648
05/22/21 08:35 PM
05/22/21 08:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
I wouldn't be afraid to bore and hone that block to 4.100 up twocents
That is a really good stock block up bow
Re: W2 stroker build - cylinder wall thickness check please [Re: Cab_Burge] #2926064
05/24/21 08:51 AM
05/24/21 08:51 AM
Windsor, ON, Canada
Windsor, ON, Canada
Originally Posted by Cab_Burge
I wouldn't be afraid to bore and hone that block to 4.100 up twocents...
So if I'm reading this right, would anything over 0.200" thickness fall into that "desired" metric than?
I realize there may not be a hard rule for this...but up to a certain power level I suppose the experience people have had with blocks probably dictates some kind of a range of thickness?
Thanks again!
Re: W2 stroker build - cylinder wall thickness check please [Re: Diplomat360] #2926208
05/24/21 03:25 PM
05/24/21 03:25 PM
I look for .160 + minimum on both thrust surfaces on any Hi Po stock block engines I build, thicker is better up
