Cat Whisker/window Sweep 70 Challenger #2924538
05/19/21 05:40 PM
05/19/21 05:40 PM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Hi
I bought a set of Top cat whisker sweeps that I'm trying to install on my '70 Challenger door panels.
It looks like they clamp on the plastic edge.
The gap looks much too small to force them on sideways and they won't slide on from the end.
Any advice would be appreciated.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Cat Whisker/window Sweep 70 Challenger [Re: Hrtbkr] #2924630
05/19/21 08:51 PM
05/19/21 08:51 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i just bought the outers....the inners look impossible to get off the panel alone..no less trying to put new ones on.. top-cat is the best ones by far however..i had the repops brand first every clip broke trying to snap them in..good luck
