Short answerer is no, but with some parts mods/swaps you can. There are two generations of post Sweptline era (72-93) body styles. 72-80 and 81-93. 72-76 use the same core support but different grills sprinkled in. 77-78 had different grills, core supports and lower grill valance (fillers) 79-80 had different grills (of which there were two different of those) and core support but back to the pre 77 lower grill valance. In 81 there was a body face lift of sorts (one Square head lamp per side and sharper body edges) 81-85 used the same grill. core support 86-mid 91 were the same onto them selves and mid 91 -93 all the same onto themselves. This is just the abridged time line. there are misc. parts and pcs that have changed as well
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
