SUSPENSION TUNING #2923407
05/17/21 10:25 AM
05/17/21 10:25 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Hello All ,
Spent all of last season fighting with my old ss spring suspension . The thread is here https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/2818578/Searchpage/2/Main/232194/Words/%2BWIRENUT/Search/true/re-update-w-video-setting-up-da-shocks.html#Post2818578
Ended up going the caltrac route , and put a bit smaller rear tire on the car to get the back down some .
Got it to the track over the weekend and it all paid off pretty well . In 5 passes got the 60' down to 1.38 and change . Last year it had slipped back to 1.45ish 1.50 . I think there is a little more in it . Please take a look and offer thoughts on adjustments moving forward.
The cal tracs are set at the baseline and did not touch them just fooled with the shocks mostly increasing rear rebound.
My thought is add some air to the tires to reduce the wrap , feed a click or two of rear rebound into it and possibly load the caltracs a little bit to reduce the hit ? Not all at once of course . I think I would start with the tires and see if it picks up .
Tires are at 9.50 lbs in this vid and et was 9.94 . I will need to slow the car down as its not certed for 9's . I will just slack the throttle cable a wee bit . That usually does it .
https://youtu.be/-EqU-IAb8qY
Re: SUSPENSION TUNING [Re: Wirenut] #2923420
05/17/21 10:51 AM
05/17/21 10:51 AM
Cab_Burge Online work
Cab_Burge  Online Work
Your doing the right thing based on your results up
Keep testing until your happy twocents
Re: SUSPENSION TUNING [Re: Wirenut] #2923472
05/17/21 12:18 PM
05/17/21 12:18 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
Wow. I could have written this same post. I departed from my SS springs back in October for Caltracs. I tried running it with the stock shocks (don't do this... lol) So, I'm waiting on my double adjustables to arrive. You car looks like it's leaving well. I'll be following this post
Jack
Re: SUSPENSION TUNING [Re: JACK1440] #2923482
05/17/21 12:52 PM
05/17/21 12:52 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Im so glad this worked out for you , as i recommended the Cal tracs....LOL
Congrats on having a car thats "too fast " now
Yes more air usually helps. Dont get hung up on the number, just keep going up 1/2 at a time and keep at it like you are
Watching that VID..... i like it. I would add more air and thats it. The seperation looks nice and controlled, Maybe one click tighter on the shock and more air,
....BAD A$$ STREET CAR.....
Re: SUSPENSION TUNING [Re: JACK1440] #2923773
05/18/21 05:37 AM
05/18/21 05:37 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Jack
What did you go with for shocks?
Re: SUSPENSION TUNING [Re: Wirenut] #2923809
05/18/21 07:47 AM
05/18/21 07:47 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have run MT slicks for many years. I have a NSS car with a 4-link. But I would say it hits the tire about as hard as your video, and has run a best of 9.64, My car likes more air in the tires, I run 10.5W 31 MT, believe it or not it has the quickest 60 foot with 15 lbs of air pressure. Most of the guys I race with have had similar experience, 12 to 15lbs works best.
Re: SUSPENSION TUNING [Re: Wirenut] #2923836
05/18/21 09:13 AM
05/18/21 09:13 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
I went with a company in PA called Competition Suspension Solutions that first fitted me with AFCO's but, they ended up being too long for my application so, now they're building me a set. I really like the guy that runs the place. Great customer service. A friend of mine who builds chassis recommended them.
His name is Shane 484-529-3501
https://www.competitivesuspension.com/
Re: SUSPENSION TUNING [Re: JACK1440] #2923932
05/18/21 11:46 AM
05/18/21 11:46 AM
ma.
duspan Offline
duspan  Offline
ma.
which hole do you have the caltrac bars in upper or lower
Re: SUSPENSION TUNING [Re: JACK1440] #2923939
05/18/21 11:55 AM
05/18/21 11:55 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
For sure I'd try some more air in the rear tires, and for sure try tightening up the front end. We always try to delay the front tire from leaving the surface until at LEAST a 1/2 turn of rear tire revolution.
It's usually a good starting point to help tune the front shocks.
What you may find is tightening the front end, and adding air pressure might get it to start spinning. You might need to loosen the rear rebound at that point to plant the tire a little harder, but in the end it will be quicker with tight front shocks, more air, and a little looser rear rebound.
All about trying things and giving it what it wants.
This is a vid of DVW's car (My Dad) I took this weekend. You can see it hardly has any separation, and has just a slow smooth long easy wheelie. 31" x 10.5w. We run 14psi in them.
https://youtu.be/D3G3mR1WxjI
Re: SUSPENSION TUNING [Re: duspan] #2924073
05/18/21 06:25 PM
05/18/21 06:25 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Lower hole. I don’t think I can use the upper as it’s blocked by the bracket
Re: SUSPENSION TUNING [Re: jwb123] #2924074
05/18/21 06:26 PM
05/18/21 06:26 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks. That is the tire size I’m running.
Re: SUSPENSION TUNING [Re: dizuster] #2924075
05/18/21 06:31 PM
05/18/21 06:31 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks I’ll play with that
Re: SUSPENSION TUNING [Re: Wirenut] #2935740
06/22/21 05:45 PM
06/22/21 05:45 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
So I wanted to ask some advice. I got back to the track , unfortunately I had no one to video . It was a much warmer day than in this last video . I couldnt get it to 60 as well as the previous outing . it was off anywhere from .03 to .07 . I only played with tire psi and shock settings front and rear and in small changes . My questions are is there a rule of thumb on direction of set up for a hoter track vs cooler ? At what point do I try changing the caltrac setting and in what direction ?
