Page 3 of 4 1 2 3 4
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2911705
04/18/21 07:02 PM
04/18/21 07:02 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
1969 Carter carb, list #4640SA. 1969 440 HP with N95 and auto trans
Came off a running motor however I would kit it or have it restored.
$120.00 plus USPS shipping
Mesa, AZ.
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2911706
04/18/21 07:14 PM
04/18/21 07:14 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Carter Competition Series AFB, #9636, 625CFM, Direct performance replacement carb for 340/383. I have two.
First one is rebuilt, $150.00 plus USPS shipping
Second one came offa running motor, $120 plus USPS shipping
PM if interested
Mesa, AZ
Re: For Sale - Big Block Engine - 2nd Quarter [Re: dart4forte] #2912004
04/19/21 04:42 PM
04/19/21 04:42 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
2 pair(4 total points)made in the usa delco remy hd dual points, solid, not vented, brass pivot, will fit all big block dual points 1958-1971 350-361-383-413-426-440 $18 mailed
cowgerwilliam035@gmail.com
a114p 005.JPG (2524 downloads)
a114p 006.JPG (2522 downloads)
a114p 008.JPG (2515 downloads)
a114p 007.JPG (2516 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: Joesixpack] #2912008
04/19/21 05:05 PM
04/19/21 05:05 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
made in the usa VCC-508 GP nors, vacuum advance, will fit;1960-1965 CHRYSLER PRESTOLITE DUAL POINTS,361-383-413-426SW, 1960-1961 DESOTO W/4 BBL IBS DIST, 1960-1971 IBS-4006,E,F, J,L,P,W,11E,IBS-4014,A&B,IBS-4017E, SERIES DUAL POINT , 9.5 L IS STAMPED ON THE ARM,$75
vcc508 001.JPG (2512 downloads)
vcc508 003.JPG (2514 downloads)
vcc508 004.JPG (2509 downloads)
vcc508 002.JPG (2512 downloads)
Throttle cable brackets [Re: moparts] #2914210
04/24/21 07:58 AM
04/24/21 07:58 AM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
Throttle cable brackets from 1969 B-RB 4bbl engines
$25 each plus ship
PM for info please
BRKT 4 SPD.jpg (2194 downloads)
BRKT AUTO.jpg (2186 downloads)
Remember when cars were FUN?
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2914757
04/25/21 01:23 PM
04/25/21 01:23 PM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
572 Predator Engine $19500 -
MOPAR Mega Block No. 5153843
Callie’s crank
Diamond Pistons
Steel Rods (don’t have paperwork for whose)
Marcella sheet metal tunnel ram
Pro Systems 9375 carbs
Titan oil pump intended for remote oil filter
Cast aluminum dragster pan (dual outlet to oil pump)
ATI Damper
Jesel Belt Drive
MSD Crank trigger
Offset Distributor (a must to clear heads)
T and D 1.8 rockers
Comp Roller cam and lifters (do have the cam card with specs.) It is a 4/7 swap.
I have a beautiful set of custom chromed dragster headers 2.5 tubes to 4.5 collector (included)
Two torque convertors for Powerglide (included)
JW Wheel (expired)
If you need more information, let me know. ron@r3solutionsonline.com
Re: For Sale - Big Block Engine - 2nd Quarter [Re: R3 Racing] #2916058
04/28/21 11:27 AM
04/28/21 11:27 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
3 Used starter metal shields look like new take offs. from a rebuilder shop$25
STARTERSHIELD 001.JPG (1845 downloads)
STARTERSHIELD 002.JPG (1842 downloads)
STARTERSHIELD 003.JPG (1841 downloads)
STARTERSHIELD 004.JPG (1849 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: Joesixpack] #2916106
04/28/21 01:10 PM
04/28/21 01:10 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
4 383-440 blasted,powder coated big block passenger side motor mount brackets, a,b,c,e body $100 for 4 mailed
bbgb 001.JPG (1820 downloads)
bbgb 002.JPG (1812 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2917688
05/02/21 01:25 PM
05/02/21 01:25 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
All Good Parts:
65-71 383 Motors $395-$1495,
68-77 440 Motors $495-$1795,
Big Block Cylinder Heads $95pr-$425pr,
65-74 Big Block 727 Transmission Cores $150-$495,
8-3/4 + Dana Shock Plates $115,
Dana Pinion Snubber $225,
Holley 650 Cfm, 700 cfm + 750 cfm Double Pumper Carburetors $195-$265,
Holley Dominator #4575 Carburetor $385,
Mr. Gasket Bug Catcher Blower Aluminum Scoop $125,
tonysparts.com
302-398-0821,
tonymopar@aol.com
Tonys Parts
Harrington Delaware 19952
Big Block Mopar Comp Cam and Lifters [Re: TONY_DAGOSTINO] #2917895
05/03/21 12:32 AM
05/03/21 12:32 AM
Seaside,Ca.
TC67CUDA Offline
TC67CUDA  Offline
Seaside,Ca.
Posting for a friend
Comp Cams XE274 Xtreme Energy Hydraulic Cam and Lifters for Big Block Mopar .488 int/.491 exh Lift
$220.00
Call Bob 831-239-3566
Re: Big Block Mopar Comp Cam and Lifters [Re: TC67CUDA] #2917940
05/03/21 09:49 AM
05/03/21 09:49 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
nors made in the usa strap style dual point big block condensers $10 each
strap 001.JPG (2195 downloads)
strap 002.JPG (2202 downloads)
strap 003.JPG (2192 downloads)
Re: Big Block Mopar Comp Cam and Lifters [Re: Joesixpack] #2918012
05/03/21 01:05 PM
05/03/21 01:05 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
3 made in the usa strap style dual point condensers, $35 mailed for all 3
al31 001.JPG (2151 downloads)
al31 004.JPG (2162 downloads)
al31 003.JPG (2168 downloads)
al31 002.JPG (2159 downloads)
1970 big block Six pack set-up. [Re: Joesixpack] #2918390
05/04/21 11:38 AM
05/04/21 11:38 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Posting for a friend. These are not my parts. Use the contact info at the bottom the ad.
For sale is a 1970 big block Six pack set-up. This is from a 1970 GTX. Call for carb numbers I don't have them handy at the moment. This is for the carbs and intake. The intake is an original aluminum Edelbrock intake.
$2595.00 plus shipping US48 only. Cash, certified bank check, or USPS money order only. NO PAYPAL or similar.
Additional pictures can be provided upon request.
Call or text Frank at 860-236-3988 for details. 9 to 8 Monday thru Saturday Eastern Time please. Located in Central Connecticut.
Common sense is a flower that does not grow in everybody's garden
69 RB shortblock and engine parts [Re: Ron_M] #2918634
05/04/21 08:28 PM
05/04/21 08:28 PM
Lake Charles, LA
calexan Offline
calexan  Offline
Lake Charles, LA
1969 440 shortblock, 0.030 over, #8 cylinder has minor problem due to rain water. The white in pictures is lithium spray grease Also Eldebrock performer RPM heads, M1 intake, Crane rockers and a pair of iron adjustable rockers, two sets of push rods mopar aluminum valve covers, extra timing gears and chain, two oil pickups, deep sump oil pan. Extra 528 purple cam with lifters. Everything in the pictures $1,200 plus shipping from 70605. All ships on one pallet. Charles text 337 853 4712 for questions, pictures.
Sold. Thanks Moparts
1965 426 Race Hemi A990 Water Pump Housing [Re: moparts] #2919694
05/07/21 02:33 PM
05/07/21 02:33 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Original 1965 426 A990 water pump housing. All threads good, no cracks. $350 plus shipping
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2919884
05/08/21 07:35 AM
05/08/21 07:35 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
K&N 3" tall oval air filter for Six Pack
https://www.knfilters.com/e-3840-oval-air-filter
This is taller than standard Six Pack air filter element.
Fit perfectly on my 440 Six Pack under my T/A hood probably won't fit under stock hood.
Very little use.
$45 plus shipping
Big Block HP Exhaust Manifolds [Re: moparts] #2920897
05/10/21 07:33 PM
05/10/21 07:33 PM
Troy,MI
Siba Offline
Siba  Offline
Troy,MI
1 pair of HP manifolds removed from a 68 b-body but will fit earlier and later models. Please research casting numbers.
These were coated to prevent rust and have held up well the last 5years. Heat riser deleted. Right side has some oil staining from valve cover leak.
Right side - 2806900
Left Side - 3671595-2 4/28/72
Hardware and heat shield included.
$475 + shipping.
Email: siba1515@yahoo.com
Thanks - Jeff
Info I have found:
CAST # side year body engine remarks
2806900 RH 1967 BC 440 HP
2806900 RH 1968-69 BC 383-440 HP
3671595 LH 1966-72 B 383-440 HP
Manley 1.81 3/8 Ste, Set of 8 New $275 [Re: Siba] #2921663
05/12/21 01:29 PM
05/12/21 01:29 PM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
Manley PN 11839-8 Stock Length Exhaust
$275 Shipped
Paypal or Venmo
Pic to come
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2922726
05/15/21 09:25 AM
05/15/21 09:25 AM
West Michigan, Usa.
K
killersix Offline
killersix  Offline
K
West Michigan, Usa.
I have a nice pair of factory 71 big block valve covers. Tabs are good just need some TLC is all. Asking $50.00 plus actual shipping. SOLD! Thanks moparts.
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2923317
05/16/21 10:26 PM
05/16/21 10:26 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1970 440 SIX PACK 4-speed setup, front carb list #4382, date code 2889, center carb list #4375, date code 3369, rear carb list #4383, date code 3149, I am selling this setup as a core to restore $2500.00 (708) 288-2879
parts 5-16-2021 087.JPG (1259 downloads)
parts 5-16-2021 090.JPG (1257 downloads)
parts 5-16-2021 093.JPG (1253 downloads)
parts 5-16-2021 096.JPG (1258 downloads)
Page 3 of 4 1 2 3 4
