Page 2 of 3 1 2 3
Re: Timing cover for a roller cam [Re: carrman] #2920462
05/09/21 04:07 PM
05/09/21 04:07 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Milodon has been making a "stock " looking TC cover for several years now. 50 bucks and they are much heavier gauge metal than stock. I use them all the time. Todd
Re: Timing cover for a roller cam [Re: sasquatch] #2920464
05/09/21 04:12 PM
05/09/21 04:12 PM
Medford, OR
carrman Offline OP
carrman  Offline OP
Medford, OR
What are you using for the timing mark indicator?
Re: Timing cover for a roller cam [Re: carrman] #2920473
05/09/21 04:44 PM
05/09/21 04:44 PM
Medford, OR
carrman Offline OP
carrman  Offline OP
Medford, OR
Would this be any heavier duty than the stock piece?
https://www.summitracing.com/parts/pro-66194/make/chrysler
Re: Timing cover for a roller cam [Re: carrman] #2920480
05/09/21 05:24 PM
05/09/21 05:24 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
yes they are heavier. They also sell a pointer for like 7 bucks. They also have the front seal but no gasket.
Todd
Re: Timing cover for a roller cam [Re: sasquatch] #2920491
05/09/21 05:39 PM
05/09/21 05:39 PM
Medford, OR
carrman Offline OP
carrman  Offline OP
Medford, OR
Todd
You talking about the Mildon or the Proform?
Re: Timing cover for a roller cam [Re: carrman] #2920513
05/09/21 07:10 PM
05/09/21 07:10 PM
Idaho
LaRoy Engines Offline
Idaho
Just me, but if I cannot afford one of the AREngineering timing covers I cannot afford to run a roller cam.
Re: Timing cover for a roller cam [Re: carrman] #2920542
05/09/21 08:35 PM
05/09/21 08:35 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Maybe I'm wrong or crazy, but the stock cover has worked for me. I thought the cam driving the oil pump puts rearward thrust on the cam? I don't know what would make the cam thrust forward (or how hard?), maybe if the oil pump was spinning faster than the cam?
Re: Timing cover for a roller cam [Re: carrman] #2920548
05/09/21 08:47 PM
05/09/21 08:47 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Does that have a torrington bearing on the back side of the cam sprocket ??
Re: Timing cover for a roller cam [Re: Stanton] #2920550
05/09/21 08:48 PM
05/09/21 08:48 PM
Medford, OR
carrman Offline OP
carrman  Offline OP
Medford, OR
Yes it does, that why I chose it.
Re: Timing cover for a roller cam [Re: carrman] #2920591
05/09/21 11:39 PM
05/09/21 11:39 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
My apologies I was strictly speaking on the Milodon unit. No info on the Proform. Todd
Re: Timing cover for a roller cam [Re: sasquatch] #2920647
05/10/21 08:50 AM
05/10/21 08:50 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Quote
You are correct. Look at the photo below. A cam rotating clockwise will drive a) the gear down and b) the cam rearward. The button is more of a precaution.
Re: Timing cover for a roller cam [Re: Stanton] #2920703
05/10/21 11:10 AM
05/10/21 11:10 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Don't think it's a problem being it's been many, many years street/strip and after the last freshon up 11 years ago, it still looked and worked great. LOTS of wives tales out there.....
Re: Timing cover for a roller cam [Re: Thumperdart] #2921187
05/11/21 01:52 PM
05/11/21 01:52 PM
Canada
RobR Offline
RobR  Offline
Canada
I put a lot of Indy covers on,starting way back in the very early 90's.First with fluid dampers and then with Innovators dampers.I just spaced the water pump out 3/4" for fluid dampers and 1" for Innovators and made my own cam buttons.I set them all at .003-.004.
Re: Timing cover for a roller cam [Re: Thumperdart] #2921226
05/11/21 03:00 PM
05/11/21 03:00 PM
an8sec70cuda Offline
iagree My 575" hemi and my wedge both have solid rollers and stock timing covers. No issues.
On the distributor collar issue...if the gear moving up and down won't affect timing, then why does the timing get much steadier after installing the collar? Is something else going on here? I've done this on both of my own engines and the timing most definitely does not move around nearly much w/ the collar on the distributor from my experience.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Timing cover for a roller cam [Re: an8sec70cuda] #2921235
05/11/21 03:25 PM
05/11/21 03:25 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Quote
Does it "really" get steadier or does it just seem that way 'cause you've just spend an hour messing with the distributor?
Honestly can't answer your question but the facts speak for themselves, the way those gears are cut there's no way that drive gear should rise up under any sort of load. If the cam moves fore or aft then, yes, timing will vary. But not because the drive is moving up or down but because its being rotated slightly from the cam movement.
Those collars were first implemented and marketed (to the best of my knowledge) by Ed Hamburger. Ed was a smallblock guy and I think a lot of guys jumped on those collars thinking they'd help on big blocks. Unless I'm mistaken, on a smallblock the cam rotation WILL drive the oil pump drive upwards and affect timing, hence the collar.
Re: Timing cover for a roller cam [Re: Stanton] #2921240
05/11/21 03:40 PM
05/11/21 03:40 PM
Originally Posted by Stanton
Quote
LOL, could be. laugh2 I could swear the timing got steadier after installing the collar. I remember being skeptical about it, but then being like...hey, that did work. It's been many years ago though. shruggy
CHIP
Re: Timing cover for a roller cam [Re: Stanton] #2921273
05/11/21 05:01 PM
05/11/21 05:01 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Quote
Beat me too it, it ain’t a CHEVY guys! Waste of time, why do you think they put the torrington bearing behind the gear?
Re: Timing cover for a roller cam [Re: Stanton] #2921295
05/11/21 05:54 PM
05/11/21 05:54 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Quote
Small blocks drive them into the bushing also....As I've said before when the engine is running you couldn't move that gear if you tried.
Re: Timing cover for a roller cam [Re: sasquatch] #2921378
05/11/21 09:03 PM
05/11/21 09:03 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I agree - I really like the one I got from you on my 505 with the roller cam and I have one on my 574 race motor now too.
Re: Timing cover for a roller cam [Re: markz528] #2922791
05/15/21 11:54 AM
05/15/21 11:54 AM
Medford, OR
carrman Offline OP
carrman  Offline OP
Medford, OR
Went with a Milodon. Ordered a timing pointer also, as the description said there wasn't one included. Cover shows up before the pointer, and there one in the package! Now I have an extra pointer.
Page 2 of 3 1 2 3
