Re: CSR shields
[Re: Chip]
#3007096
01/20/22 09:05 AM
01/20/22 09:05 AM
Posts: 34,927 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Yeah, she wanted me to pre-pay also , I said no thanks and bought ALUMINUM one from TCI .. my tunnel is large so no worry about fit
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: CSR shields
[Re: bigdad]
#3007187
01/20/22 01:44 PM
01/20/22 01:44 PM
Posts: 19,464 north of coder
moparx
the thing about the aluminum shields is the certification. how does that thing go "bad" after 5 [?] years unless the transmission blows up, deforming it, or it is cut up into chunks. just as bad as the seat belt fiasco in my opinion. [ya know, grumpy old guy muttering in his oatmeal...... ]
Re: CSR shields
[Re: moparx]
#3007221
01/20/22 02:49 PM
01/20/22 02:49 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I just wanted some level of protection, Not to worried about the cert baloney
Re: CSR shields
[Re: bigdad]
#3007416
01/20/22 10:31 PM
01/20/22 10:31 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
I just wanted some level of protection, Not to worried about the cert baloney Then put a steel drum in it and forget the shield.
Re: CSR shields
[Re: GomangoCuda]
#3007417
01/20/22 10:32 PM
01/20/22 10:32 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I just wanted some level of protection, Not to worried about the cert baloney Then put a steel drum in it and forget the shield. Steel or aluminum with a steel liner
Re: CSR shields
[Re: Cab_Burge]
#3007418
01/20/22 10:42 PM
01/20/22 10:42 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
They do already
do you understand what is meant by a level of security?
Re: CSR shields
[Re: bigdad]
#3007422
01/20/22 10:46 PM
01/20/22 10:46 PM
GomangoCuda
They do already
do you understand what is meant by a level of security? Do steel drums explode?
Re: CSR shields
[Re: bigdad]
#3007479
01/21/22 07:04 AM
01/21/22 07:04 AM
Posts: 1,113 Usa
A39Coronet
Usa
Yeah, she wanted me to pre-pay also , I said no thanks and bought ALUMINUM one from TCI .. my tunnel is large so no worry about fit Tunnel better be huge cause the tci shield is pretty much made for dragsters. No way that's fitting in a basic tunnel. Maybe someone can share their success with it, but one look at it and mine went back.
Re: CSR shields
[Re: GomangoCuda]
#3007490
01/21/22 09:18 AM
01/21/22 09:18 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
They do already
do you understand what is meant by a level of security? Do steel drums explode? Anything is possible , just take several safety measures that you can
Re: CSR shields
[Re: A39Coronet]
#3007491
01/21/22 09:21 AM
01/21/22 09:21 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Yeah, she wanted me to pre-pay also , I said no thanks and bought ALUMINUM one from TCI .. my tunnel is large so no worry about fit Tunnel better be huge cause the tci shield is pretty much made for dragsters. No way that's fitting in a basic tunnel. Maybe someone can share their success with it, but one look at it and mine went back. prepared for that
Re: CSR shields
[Re: bigdad]
#3007492
01/21/22 09:23 AM
01/21/22 09:23 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Speaking from experience .. Most stock floors will not clear the CSR shield either .. i've owned two cars that I put them on , my current 67 has one
Re: CSR shields
[Re: GomangoCuda]
#3007498
01/21/22 09:46 AM
01/21/22 09:46 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
Stock 727 drums definitely have that capability….. smaller mass of the 904, haven’t heard of it happening. …..and we’re not talking huge hp deals either.
Re: CSR shields
[Re: bigdad]
#3007673
01/21/22 06:32 PM
01/21/22 06:32 PM
Posts: 1,113 Usa
A39Coronet
Usa
Speaking from experience .. Most stock floors will not clear the CSR shield either .. i've owned two cars that I put them on , my current 67 has one Agreed, had to bash my 67 to get mine in as well, and that is basically a direct overlay design.
Re: CSR shields
[Re: scottb]
#3007778
01/22/22 07:36 AM
01/22/22 07:36 AM
Posts: 2,046 MD
RTSE4ME
MD
Just ordered one she said 6-8 wks we will see she did not ask for payment I was shocked Summit has a similar eta.
