Re: 318 build
[Re: Mr PotatoHead]
#2938412
06/30/21 04:08 PM
06/30/21 04:08 PM
Posts: 15,487 Florida
scratchnfotraction
Can you post intake pics? sure. I will take some pics tonight. I will be running a Holley Street Dominator intake with a Holley 650cfm vac spredbore carb ( q-jet replacement for 85 d150 I got NOS/NIB from a military surplus sale.) I added a QFT adjustable vac pod to it. I have found this is well worth the 40bux for dialing in a vac 2ndary carb over the R&R pod spring. 2nd choice is my LD4B intake with the 650cfm double pumper. I will run the 4 speed with this combo. I also have a eddy performer RPM-airgap intake with a 750cfm dp that I modified to use an 850cfm throttle plate on. gasket match main body to the 850 throttle plate for 1 3/8" ventures 1 3/4" throttle blades. squared up air bleeds/jets converted it to 4 corner idle lots of velocity and throttle response with this mod and it is 40 yrs old and works good as a new high $ shiny carb. moparlarry360 is helping me with the pic posting and will come when he has the spare time to post them... THANKS Larry!!
Re: 318 build
[Re: redraptor]
#2941136
07/08/21 10:47 AM
07/08/21 10:47 AM
Posts: 15,822 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Progress. Crank in & torqued. Pistons in & Rods torqued. Oil galley plugs in & intermediate bushimg in.
Facts are stubborn things.
Re: 318 build
[Re: larrymopar360]
#2941225
07/08/21 03:06 PM
07/08/21 03:06 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Did you get the pistons zero decked?
