Valve Spacing, piston relief location
#2919212
05/06/21 09:13 AM
05/06/21 09:13 AM
Posts: 16,923 NC
440Jim
NC
The topic about Jesel 440-1 rockers and Indy 572-13 heads got me wondering about the valve angles, valve spacing, and location. My internet searches produced little info, so tell me what you know.
Cyl Head ________Angle__Spacing__Exh____Int offset Stock 440 _______15 deg Indy 440-1 ______15 deg Indy 572-13 _____13 deg Koffels B1 original 15 deg Koffels B1-MC ___15_deg
Re: Valve Spacing, piston relief location
[Re: 440Jim]
#2919261
05/06/21 11:25 AM
05/06/21 11:25 AM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
b1 and b1MC are both 15 deg, the spacing on the b1 is stock and the MC is spread (i believe) .400 total
Joe
Without Data, you’re just another guy with an opinion.
[Re: fbs63]
#2920629
05/10/21 08:00 AM
05/10/21 08:00 AM
Posts: 16,923 NC
440Jim
NC
The valve centerline on B1,B1mc,572-13 and 600-13 are all moved to open on the cylinder centerline. So the valve notches are higher on the piston. The B1 mc is also spread to accept a 2.400 intake valve IIRC .060" Are you saying the B1 heads have the valves moved "up" in my picture above? How much? Is the 0.060" spacing change you listed moving each 0.030" toward the cylinder walls or some other combination such as moving the exhaust toward the cylinder wall (left) and the intake away (also moving left)?
[Re: 440Jim]
#2920633
05/10/21 08:22 AM
05/10/21 08:22 AM
Posts: 16,923 NC
440Jim
NC
I just received this email from Scott Koffel, responding to my email on valve reliefs. It has been too long since we actually cut a set here. You are stock 15 degree but the notches are moved to open on cylinder centerline. If you call wiseco and ask for Vic Ellinger he should be able to answer those questions. Typ we have the notches .300 deep so if you are trying to renotch std 440 pistons won't work on most as head of piston not thick enough and top ring position too high on most std pistons that intake notch falls into top ring.
