Torsion bars still won't budge...HELP PLEASE. #291895
04/18/09 03:14 PM
04/18/09 03:14 PM
Tenn.
jrwoodjoe Offline OP
Tenn.
The car is on stands with no load on the suspension, the tensioners have been loosened and the bump stop removed. Using a torsion bar tool, I have banged and banged on them with no luck. Some of you have mentioned loosening the lower control arm and then knocking it back to force the torsion bar out. So I may try that now but have 2 questions.
Question 1: I have the jack stands supporting the frame rails at the firewall area. Is the front of the car flexing to the point that it is still causing the tension on the bars? I have a photo showing where the jack stand is located.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: jrwoodjoe] #291896
04/18/09 03:15 PM
04/18/09 03:15 PM
Tenn.
Tenn.
Question 2: To loosen the lower control arm I will need to loosen the nut in the photo and then knock the Bolt towards the rear of the car...correct?
Thanks.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: jrwoodjoe] #291897
04/18/09 03:31 PM
04/18/09 03:31 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
My rust free 65 flexed bad when I put the jack stands in that spot with a 440 in it. Now i use the k-frame.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: jrwoodjoe] #291898
04/18/09 03:32 PM
04/18/09 03:32 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Yes, tap the lower control arm towards the rear. I wouldn`t tap on the bolt. I tapped on the control arm with a piece of wood for cushion. Also, put a jack under the k frame to relieve the stress.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: jrwoodjoe] #291899
04/18/09 03:33 PM
04/18/09 03:33 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try melting some wax around the hexs.I had one in the 65 that wouldnt budge.Heated the hex with a propane torch and melted a bees wax candle in it and it came right out.Rocky
Chrysler Firepower
Re: Torsion bars still won't budge...HELP PLEASE. [Re: jrwoodjoe] #291900
04/18/09 04:23 PM
04/18/09 04:23 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Probably a silly question, but I assume that you removed the lock rings at the back of the T-bar anchors? I have had a couple of tough t-bar removals and usually a BIG hammer does the job with some PB blaster sprayed in the sockets.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: jrwoodjoe] #291901
04/18/09 04:47 PM
04/18/09 04:47 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i noticed that no one else mentioned it so... don't forget to also remove the nut on the front of the strut rod or the lower control arm won't budge either.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: dirtybee] #291902
04/18/09 06:29 PM
04/18/09 06:29 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
sometimes if the car hasn't been driven in some time the tension arms for the torsion bars rust in place. just because you loosened the bolt doesn't mean you released the tension on them. maybe check that.
also i just removed a torsion bar to replace the starter and had to loosen the nut in the suspension pic to get the are to release enough to reinstall the bar.
another simple thing that is sometimes forgotten is the clip at the rear of the bar. did you remove them? i don't think they will hold the bars in that good but you never know.
just tossing those ideas at you.
perception is 90% of reality
Re: Torsion bars still won't budge...HELP PLEASE. [Re: 70440+6bbl] #291903
04/18/09 07:04 PM
04/18/09 07:04 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Re: Torsion bars still won't budge...HELP PLEASE. [Re: 70440+6bbl] #291904
04/18/09 07:43 PM
04/18/09 07:43 PM
Tenn.
Tenn.
Thanks but yes, that was the first thing I did.
Thanks, They are extremely loose and wriggle around so I don't see a problem there.
The one thing I noticed was that that the torsion bar at the rear mount looked like it was "pushed up", I'm starting to think that the reason is the front end of the car is flexed down causing it to bind some. I'm going to jack some tension off the front end as some of you have mentioned to see if that helps. I'll also shoot some WD-40 or Blaster on the bushings tap the control arm back as suggested. Probably be a few days before I can work on it again. Thanks for all the advice everyone. It very much appreciated.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: mopars4ever] #291905
04/18/09 07:52 PM
04/18/09 07:52 PM
Tenn.
Tenn.
Thanks, I wasn't thinking when I said tap the bolt.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: jrwoodjoe] #291906
04/19/09 12:26 AM
04/19/09 12:26 AM
MNobody Offline
MNobody  Offline
I had one bar on my coronet that wouldn't budge, when i backed off the adjuster the arm didn't rotate down it was froze where it pivots. I beat the crap outta that bar even with the correct clamping block on it until i realized what was going on.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: jrwoodjoe] #291907
04/19/09 07:11 AM
04/19/09 07:11 AM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
I recently had a problem installing some torsion bars as my lower control arm would not droop enough for the hex to align with the torsion bar. I loosened the upper ball joint (with a ball joint remover keeping the nut on but loosened so the whole brake assembly wouldnt drop). This allowed the lower control arm to fall enough for me to install the torsion bar easily.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: Blakcharger440] #291908
04/20/09 05:40 AM
04/20/09 05:40 AM
runningman Offline
super street
runningman  Offline
super street
I had some problems with mine recently also, I loosened the LCA nut and used a pry bar between the k-frame and LCA and pushed the entire assembly back with broke the torsion bar free.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: runningman] #291909
04/20/09 12:46 PM
04/20/09 12:46 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Having parted an untold number of Mopars over 30 years,...I've come across a few torsion bar removal problem were the hex end swelled, and distorted the hex receiver in the crossmember, the bar seemed loose, but wouldn't slide out.......remedy, lose the bar, cut it, so you can slide the rear cut section of bar forward out of the hex,.....now you can file, or dremel the rear of the hex bore to size, to slide in your replacement
Re: Torsion bars still won't budge...HELP PLEASE. [Re: DAYCLONA] #291910
04/20/09 01:30 PM
04/20/09 01:30 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Hit the socket on the LCA that the bar slips in with a hammer, sometimes this helps.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: pushbutton] #291911
04/20/09 04:38 PM
04/20/09 04:38 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
When I took mine off I had a similar problem on the drivers side. As I am doing a complete rebuild, I loosened the LCA all the way and finally just took an angle grinder and cut the stupid bar. I was positive there was no pressure on the bar and their wasn't, but I sure was nervous as all heck while doing it. Finally, I beat the bars out from the back as even with cutting them and pulling the one end out the front, the back would just not budge.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: Torsion bars still won't budge...HELP PLEASE. [Re: runningman] #291912
04/20/09 06:55 PM
04/20/09 06:55 PM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
Yup - just did that same thing about a week ago. 3 foot claw-bar between the K-Frame and the LCA.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: jrwoodjoe] #291913
04/22/09 04:50 AM
04/22/09 04:50 AM
Martinez, California
Challenged Offline
Challenged  Offline
A couple years ago I had allot of trouble removing mine. I eventually ended up putting a floor jack under the LCA and raising it a bit while checking the t-bar side, I could actually see the LCA loosen up around the T-bar when the flat areas lined up, this also helps if you have trouble reinstalling the t-bars. Before putting the t-bars back in I gave them a good greasing at both ends, recently I removed them again and they came out easily.
Re: Torsion bars still won't budge...HELP PLEASE. [Re: jrwoodjoe] #291914
04/24/09 11:37 PM
04/24/09 11:37 PM
PA
moparboy66 Offline
moparboy66  Offline
PA
I had to cut one off on my '66 Coronet. I then saw the LCA bushing holding the pivot arm was so worn out to one side, that the torsion bar still had tension on it. The harder I hit it, I simply increased the tension momentarily. I finally cut the bar, and both end simply dropped out.
