Page 1 of 3 1 2 3
Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching #2918745
05/05/21 07:26 AM
05/05/21 07:26 AM
Almost Heaven
Not yr uncle Bob Offline OP
Almost Heaven
https://www.ebay.com/itm/133751228608
Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching Drive Train
I can't help it, I always wonder why people restore a car then put load assist shocks, shock extensions, or air shocks on the rear. Just buy new springs people.
Everybody makes fun of a hillbilly until they need something fixed.
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: Not yr uncle Bob] #2918760
05/05/21 09:10 AM
05/05/21 09:10 AM
E Tennessee
W
wmdj5 Offline
wmdj5  Offline
W
E Tennessee
Yeah, or if you absolutely had to have the original springs, you could take them to a spring shop and have them recurved.
Plenty or repro or incorrect parts on this car anyway, new springs wouldn't hurt it. shruggy
Is that hood correct? Black scoops on a white hood? Did Chrysler really do that?
I'm sorry, without some stripes or something to blend them in, they look like warts. down
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: wmdj5] #2918766
05/05/21 09:15 AM
05/05/21 09:15 AM
E Tennessee
W
wmdj5 Offline
wmdj5  Offline
W
E Tennessee
The color of those wheels doesn't look like body color.
Is that just the light in the picture, or is that Krylon white on the wheels?
Too many little things cheaped out on, to be trying for $100K.
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: wmdj5] #2918778
05/05/21 09:48 AM
05/05/21 09:48 AM
S. Central PA
sixpakdodge Offline
sixpakdodge  Offline
S. Central PA
What a turd. Car is loaded with parts store electronics, hoses, etc. Trans stamp is pretty fresh looking, engine stamp pic isn't too close, but appears to be crisp/straight. I'm guessing a re-stamped warranty block and machined/stamped transmission.
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: Not yr uncle Bob] #2918784
05/05/21 10:08 AM
05/05/21 10:08 AM
SE Pa.
LimeliteAero Offline
SE Pa.
Is that the correct place for the air grabber cable?
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: LimeliteAero] #2918802
05/05/21 10:38 AM
05/05/21 10:38 AM
69x Offline
69x  Offline
Hood Scoops should be body color and its a 'Ramcharger' not an 'Air Grabber'
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: sixpakdodge] #2918814
05/05/21 11:16 AM
05/05/21 11:16 AM
Almost Heaven
Almost Heaven
Originally Posted by sixpakdodge
What a turd.
I own "turds" so I know what one is and this car is not one. It is probably way overpriced, but it is definitely not a turd.
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: LimeliteAero] #2918820
05/05/21 11:31 AM
05/05/21 11:31 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
No, that is where the tach wire (if optioned N85) would be located. I've seen two locations for N96 equipped '70 Dodges. One is just under the voltage regulator and the other is where you'd find the N96 hoses on a Plymouth come out of.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: 70440+6bbl] #2918833
05/05/21 11:58 AM
05/05/21 11:58 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Super Track Pack, but is that a drum brake m/c? The black scoops look awful. What a cool car, though, issues aside.
Earning every penny of that moderator paycheck.
DBAP
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: 70440+6bbl] #2918876
05/05/21 01:35 PM
05/05/21 01:35 PM
SE Pa.
SE Pa.
It's where the vacuum lines for the headlights came through on my superbird too.
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: LimeliteAero] #2918892
05/05/21 02:20 PM
05/05/21 02:20 PM
my own world
theraif Offline
theraif  Offline
my own world
after restored
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: LimeliteAero] #2918895
05/05/21 02:23 PM
05/05/21 02:23 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yeah it’s a turd! What were they thinking?
I like the door latch hardware, CLASSY!
And the high dollar wiper motor restoration.
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: NANKET] #2918919
05/05/21 03:42 PM
05/05/21 03:42 PM
69x Offline
69x  Offline
Can someone explain the 2nd tag ? 'Body in White Special order'
Turd or not its a very rare car.
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: 69x] #2918966
05/05/21 05:21 PM
05/05/21 05:21 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
That second tag was not factory installed...I used to get them off 80's NY state retired trooper cars with just those two lines or 4 lines...gave many away to friends.
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: Not yr uncle Bob] #2919000
05/05/21 06:50 PM
05/05/21 06:50 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
What a turd.
Agreed,
The trans is obviously a restamp. the engine I would prefer to see in person before passing judgment
The car has its issues and not knowing what the reserve its hard to say if its overpriced or not.
1970 Hemi R/Ts don't pop up very often so I couldn't say if its overpriced or not.
But most of the issues I see could be easily corrected without spending a ton of money.
Now, That said. I have always liked the 70 Coronets . But Would I trade him straight up?................. NOPE
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: gtx6970] #2919104
05/05/21 10:26 PM
05/05/21 10:26 PM
Eagle, Idaho
Neil Offline
Neil  Offline
Eagle, Idaho
Wrong year hubcaps and little stuff here and there. Worse offense for a car in that price range is the painted bottom. Rest looks ok to fixable with a few weekends worth of tinker work if you wanted it more '1970 correct'.
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: Neil] #2919135
05/05/21 11:43 PM
05/05/21 11:43 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the ad & pictures do not instill confidence, but what a RARE car penguin if legit ??
do the seller's other auctions cause concern? work what a TRAINWRECK hammer FAKE fender tag does NOT help runaway
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: 6bblgt] #2919147
05/06/21 12:22 AM
05/06/21 12:22 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yowzers
work eek
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: 6bblgt] #2919206
05/06/21 08:54 AM
05/06/21 08:54 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Just as easily being selling off spare parts from a parts car ( not uncommon at all )
Like I said if its legit its a pretty rare car and would need ckd out in person before any money changes hands . ESPECIALLY at this price point.
And to think I almost bought a limelight version years ago . ( like well over 30 years back ) Owner wanted something like $12,500, I offered 10k
and walked away from it. Yeah,I know that was a ,,HUGE mistake .
Guy had a limelight 1970 Coronet RT and a bronze 1969 hemi Charger RT. Best I remember he wanted 25k for both cars
Re: Original 1970 R Code R/T 426 Hemi Coronet Numbers Matching [Re: 6bblgt] #2919316
05/06/21 12:38 PM
05/06/21 12:38 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
looks like it may have been a 500 at one time.. doh
Page 1 of 3 1 2 3
