Page 4 of 4 1 2 3 4
Re: 426 wedge [Re: mopar muscle7271] #2914190
04/24/21 02:14 AM
04/24/21 02:14 AM
[quote=jahns is called je pistons now [/quote]
I was not aware of that, thanks for sharing up
They were one of the few piston company I can remember from the early 1960 when I first got into hot rodding and drag racing. I'm sure there were others making them like SilvoLite, badger and so on.
SRP is a sister company to JE for street use, they are on the same web site, I was told that years ago that the Calvert Bros, not John Calvert the drag racer, I don't think he is related to them, sold JE and had a 5 year no compete contract.
They later bought out Carrillo Rods and started CP pistons after getting back into the hot rod market several years back shruggy
Good luck on your deal thumbs
Re: 426 wedge [Re: Cab_Burge] #2914279
04/24/21 11:46 AM
04/24/21 11:46 AM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
Oh l see thanks if can find some bushings for rods or get some custom made that be better won't have to mess with piston wirst holes at all. If l get end up gettin the pistons
Re: 426 wedge [Re: mopar muscle7271] #2917564
05/02/21 07:56 AM
05/02/21 07:56 AM
las vegas,nv
las vegas,nv
Someone offer me some L2185 426 max wedge pistons. Anyone know anything about the old L2185 pistons?
Re: 426 wedge [Re: mopar muscle7271] #2917640
05/02/21 11:45 AM
05/02/21 11:45 AM
Transman Offline
Transman  Offline
They are high ratio. I think 12.5, I think the 2184 is 11.5 to 1.
Re: 426 wedge [Re: Transman] #2918173
05/03/21 07:58 PM
05/03/21 07:58 PM
las vegas,nv
las vegas,nv
Ok how would you reduce the compression down on them? Like a 10:1
Re: 426 wedge [Re: mopar muscle7271] #2918213
05/03/21 09:43 PM
05/03/21 09:43 PM
Transman Offline
Transman  Offline
First you need to calculate what the ratio would be now.
What is the deck height, chamber volume, bore and stoke.
Then plug in the dome volume.
Thick gasket may be enough or may need to whack the dome.
Re: 426 wedge [Re: Transman] #2918221
05/03/21 09:50 PM
05/03/21 09:50 PM
Florida STAYcation
Doc Fiberglass Online content
Moparts Biggest Richard Head
Doc Fiberglass  Online Content
Florida STAYcation
There you go Tman ...
How about initially a pic of the dome .. then that spec
Then the compression distance
Moi ? A biggie Richard Head ? Me thimks someone needs a cuddly ESA or a box of generously lotioned tissues !
Re: 426 wedge [Re: Transman] #2918236
05/03/21 10:27 PM
05/03/21 10:27 PM
las vegas,nv
las vegas,nv
4-1/4 5/64,5/64,3/16 13.56:1 2.3765comp. That's what it's says the compression is for the L2185
Page 4 of 4 1 2 3 4
