Page 3 of 3 1 2 3
Holley 3310-2 750 vac secondary carb [Re: 19Coronet66] #2911427
04/17/21 08:05 PM
04/17/21 08:05 PM
Cleveland, Ohio
northcoastmopar Offline
Cleveland, Ohio
Holley 3310-2 vac secondary with dual metering blocks. Also has quick change secondary kit. Stored indoors for several years, moves freely but should be rebuilt. Just realized it's missing the choke, so lower price. If it's still too high, make me an offer.
$75 + shipping.
PM me here or jdgstreet@gmail.com
Thanks moparts
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2911705
04/18/21 07:02 PM
04/18/21 07:02 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
1969 Carter carb, list #4640SA. 1969 440 HP with N95 and auto trans
Came off a running motor however I would kit it or have it restored.
$120.00 plus USPS shipping
Mesa, AZ.
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2911706
04/18/21 07:14 PM
04/18/21 07:14 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Carter Competition Series AFB, #9636, 625CFM, Direct performance replacement carb for 340/383. I have two.
First one is rebuilt, $150.00 plus USPS shipping
Second one came offa running motor, $120 plus USPS shipping
PM if interested
Mesa, AZ
Re: For Sale - Big Block Engine - 2nd Quarter [Re: dart4forte] #2912004
04/19/21 04:42 PM
04/19/21 04:42 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
2 pair(4 total points)made in the usa delco remy hd dual points, solid, not vented, brass pivot, will fit all big block dual points 1958-1971 350-361-383-413-426-440 $18 mailed
cowgerwilliam035@gmail.com
a114p 005.JPG (1251 downloads)
a114p 006.JPG (1250 downloads)
a114p 008.JPG (1249 downloads)
a114p 007.JPG (1249 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: Joesixpack] #2912008
04/19/21 05:05 PM
04/19/21 05:05 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
made in the usa VCC-508 GP nors, vacuum advance, will fit;1960-1965 CHRYSLER PRESTOLITE DUAL POINTS,361-383-413-426SW, 1960-1961 DESOTO W/4 BBL IBS DIST, 1960-1971 IBS-4006,E,F, J,L,P,W,11E,IBS-4014,A&B,IBS-4017E, SERIES DUAL POINT , 9.5 L IS STAMPED ON THE ARM,$75
vcc508 001.JPG (1243 downloads)
vcc508 003.JPG (1243 downloads)
vcc508 004.JPG (1243 downloads)
vcc508 002.JPG (1249 downloads)
Throttle cable brackets [Re: moparts] #2914210
04/24/21 07:58 AM
04/24/21 07:58 AM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
Throttle cable brackets from 1969 B-RB 4bbl engines
$25 each plus ship
PM for info please
BRKT 4 SPD.jpg (924 downloads)
BRKT AUTO.jpg (922 downloads)
Remember when cars were FUN?
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2914757
04/25/21 01:23 PM
04/25/21 01:23 PM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
572 Predator Engine $19500 -
MOPAR Mega Block No. 5153843
Callie’s crank
Diamond Pistons
Steel Rods (don’t have paperwork for whose)
Marcella sheet metal tunnel ram
Pro Systems 9375 carbs
Titan oil pump intended for remote oil filter
Cast aluminum dragster pan (dual outlet to oil pump)
ATI Damper
Jesel Belt Drive
MSD Crank trigger
Offset Distributor (a must to clear heads)
T and D 1.8 rockers
Comp Roller cam and lifters (do have the cam card with specs.) It is a 4/7 swap.
I have a beautiful set of custom chromed dragster headers 2.5 tubes to 4.5 collector (included)
Two torque convertors for Powerglide (included)
JW Wheel (expired)
If you need more information, let me know. ron@r3solutionsonline.com
Re: For Sale - Big Block Engine - 2nd Quarter [Re: R3 Racing] #2916058
04/28/21 11:27 AM
04/28/21 11:27 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
3 Used starter metal shields look like new take offs. from a rebuilder shop$25
STARTERSHIELD 001.JPG (588 downloads)
STARTERSHIELD 002.JPG (591 downloads)
STARTERSHIELD 003.JPG (587 downloads)
STARTERSHIELD 004.JPG (586 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: Joesixpack] #2916106
04/28/21 01:10 PM
04/28/21 01:10 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
4 383-440 blasted,powder coated big block passenger side motor mount brackets, a,b,c,e body $100 for 4 mailed
bbgb 001.JPG (568 downloads)
bbgb 002.JPG (563 downloads)
"NEW" Holley 850 CFM Carburetor #80531 [Re: moparts] #2917654
05/02/21 12:24 PM
05/02/21 12:24 PM
Northwest Indiana
19Coronet66 Offline
19Coronet66  Offline
Northwest Indiana
For sale is a new Holley 850 CFM carburetor. Holley part number 80531. Vacuum secondary's. Electric choke. No attempt was made to install it. $375 plus shipping.
https://www.summitracing.com/parts/hly-0-80531
PM if interested
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2917688
05/02/21 01:25 PM
05/02/21 01:25 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
All Good Parts:
65-71 383 Motors $395-$1495,
68-77 440 Motors $495-$1795,
Big Block Cylinder Heads $95pr-$425pr,
65-74 Big Block 727 Transmission Cores $150-$495,
8-3/4 + Dana Shock Plates $115,
Dana Pinion Snubber $225,
Holley 650 Cfm, 700 cfm + 750 cfm Double Pumper Carburetors $195-$265,
Holley Dominator #4575 Carburetor $385,
Mr. Gasket Bug Catcher Blower Aluminum Scoop $125,
tonysparts.com
302-398-0821,
tonymopar@aol.com
Tonys Parts
Harrington Delaware 19952
Big Block Mopar Comp Cam and Lifters [Re: TONY_DAGOSTINO] #2917895
05/03/21 12:32 AM
05/03/21 12:32 AM
Seaside,Ca.
TC67CUDA Offline
TC67CUDA  Offline
Seaside,Ca.
Posting for a friend
Comp Cams XE274 Xtreme Energy Hydraulic Cam and Lifters for Big Block Mopar .488 int/.491 exh Lift
$220.00
Call Bob 831-239-3566
Re: Big Block Mopar Comp Cam and Lifters [Re: TC67CUDA] #2917940
05/03/21 09:49 AM
05/03/21 09:49 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
nors made in the usa strap style dual point big block condensers $10 each
strap 001.JPG (399 downloads)
strap 002.JPG (401 downloads)
strap 003.JPG (399 downloads)
Re: Big Block Mopar Comp Cam and Lifters [Re: Joesixpack] #2918012
05/03/21 01:05 PM
05/03/21 01:05 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
3 made in the usa strap style dual point condensers, $35 mailed for all 3
al31 001.JPG (361 downloads)
al31 004.JPG (361 downloads)
al31 003.JPG (369 downloads)
al31 002.JPG (362 downloads)
1970 big block Six pack set-up. [Re: Joesixpack] #2918390
05/04/21 11:38 AM
05/04/21 11:38 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Posting for a friend. These are not my parts. Use the contact info at the bottom the ad.
For sale is a 1970 big block Six pack set-up. This is from a 1970 GTX. Call for carb numbers I don't have them handy at the moment. This is for the carbs and intake. The intake is an original aluminum Edelbrock intake.
$2595.00 plus shipping US48 only. Cash, certified bank check, or USPS money order only. NO PAYPAL or similar.
Additional pictures can be provided upon request.
Call or text Frank at 860-236-3988 for details. 9 to 8 Monday thru Saturday Eastern Time please. Located in Central Connecticut.
Common sense is a flower that does not grow in everybody's garden
69 RB shortblock and engine parts [Re: Ron_M] #2918634
05/04/21 08:28 PM
05/04/21 08:28 PM
Lake Charles, LA
calexan Offline
calexan  Offline
Lake Charles, LA
1969 440 shortblock, 0.030 over, #8 cylinder has minor problem due to rain water. The white in pictures is lithium spray grease Also Eldebrock performer RPM heads, M1 intake, Crane rockers and a pair of iron adjustable rockers, two sets of push rods mopar aluminum valve covers, extra timing gears and chain, two oil pickups, deep sump oil pan. Extra 528 purple cam with lifters. Everything in the pictures $1,200 plus shipping from 70605. All ships on one pallet. Charles text 337 853 4712 for questions, pictures. Thanks Moparts
Page 3 of 3 1 2 3
