Rear disc brake caliper mounting #2917795
05/02/21 07:03 PM
05/02/21 07:03 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I putting Strange rear brakes on a friends 67 GTX and the caliper brackets are configured so they mount in front of the axle. I have seen pictures of them mounted on either side of the axle and rear mounted seems to be most popular. The way the nutserts are installed in the brackets I can't safely bolt the calipers on the rear. Is there any downside to mounting the calipers forward shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Rear disc brake caliper mounting [Re: fourgearsavoy] #2917830
05/02/21 08:31 PM
05/02/21 08:31 PM
AndyF Offline
AndyF  Offline
Most important thing is to have the bleeders point up so you can bleed all of the air out. That is about the only issue with caliper mounting other than the obvious issue of interference with something.
Re: Rear disc brake caliper mounting [Re: fourgearsavoy] #2917912
05/03/21 06:47 AM
05/03/21 06:47 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
Swap the bracket from one side to the other??
Re: Rear disc brake caliper mounting [Re: 80arrow] #2917931
05/03/21 08:56 AM
05/03/21 08:56 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Many books cover caliper mounting. A front mounted caliper will cause the body to dive under braking. When the body dives its reducing pressure on the contact patch. A rear mounted caliper causes the body to lift, increasing pressure on the contact patch. You want rear mounted calipers if at all possible.
Re: Rear disc brake caliper mounting [Re: Stanton] #2917963
05/03/21 11:07 AM
05/03/21 11:07 AM
AndyF Offline
AndyF  Offline
Mounting position has zero effect on the chassis reaction.
Re: Rear disc brake caliper mounting [Re: 80arrow] #2917997
05/03/21 12:26 PM
05/03/21 12:26 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
