Painting gas tank filler tube question #2915691
04/27/21 01:35 PM
04/27/21 01:35 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I'm putting a new gas tank in my Dart and due to it being pretty grungy and having some rust, I media blasted the filler tube and am going to paint it. My question is, is it O.K. to paint it all the way to the end that goes in the tank or should I only paint it to the flange where the tube enters the tank and leave the end bare?
Re: Painting gas tank filler tube question [Re: 1970RT] #2915733
04/27/21 03:00 PM
04/27/21 03:00 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
There is a company that you can send it to and they will put the tin/lead coating back on it.
Re: Painting gas tank filler tube question [Re: burdar] #2915746
04/27/21 03:21 PM
04/27/21 03:21 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
I’d go this route if you can.
China is the enemy.
Re: Painting gas tank filler tube question [Re: 1972CudaV21] #2915809
04/27/21 05:59 PM
04/27/21 05:59 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Paint & gasoline generally are not a good mix.
If you go with paint, I'd say leave anything that contacts fuel bare.
By the same token, I wouldn't want that area to rust.
I agree that plating would be the best.
Re: Painting gas tank filler tube question [Re: 1970RT] #2915845
04/27/21 07:17 PM
04/27/21 07:17 PM
IMGTX Offline
IMGTX  Offline
If you don't go back with the tin plating maybe painting the outside with a fuel tank liner/sealer is an option.
https://www.eastwood.com/catalogsearch/result/?q=fuel+tank
Re: Painting gas tank filler tube question [Re: IMGTX] #2916025
04/28/21 09:32 AM
04/28/21 09:32 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
China is the enemy.
Re: Painting gas tank filler tube question [Re: 1972CudaV21] #2916283
04/28/21 08:11 PM
04/28/21 08:11 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
I have painted origianl gas tanks and filler tubes with Rustoleum Silver Hammertone Paint and it looked like original zinc when done. I have passed it off in some tough judging shows as original. People could not believe how close to original the paint looked on the gas tank. Just my input.
Re: Painting gas tank filler tube question [Re: maximus] #2916311
04/28/21 09:34 PM
04/28/21 09:34 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Do you have any pictures of your painted gas tank? Thanks!
China is the enemy.
Re: Painting gas tank filler tube question [Re: 1972CudaV21] #2916396
04/29/21 07:12 AM
04/29/21 07:12 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Sorry, I don't have a good picture of the tank. It was on a near concourse restoration of my 1969 Charger R/T SE car. For $8 you can pick up a spray can and test it out on some other metal part. It gives the correct texture and appearance of zinc finish.
Re: Painting gas tank filler tube question [Re: 1970RT] #2916455
04/29/21 09:21 AM
04/29/21 09:21 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Sounds like you may have already removed the coating, but I was able to clean mine up with steel wool and WD40. Removed the crud, but didn't remove the lead coating.
Re: Painting gas tank filler tube question [Re: maximus] #2916521
04/29/21 12:38 PM
04/29/21 12:38 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Sounds good👍
China is the enemy.
