Re: anti reversion chambers/mufflers
[Re: mgoblue9798]
#2914985
04/25/21 11:28 PM
04/25/21 11:28 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
Never heard of them, what are they?
[Re: DAYCLONA]
#2915459
04/26/21 09:42 PM
04/26/21 09:42 PM
Posts: 1,060 Atlanta, GA
mgoblue9798
Atlanta, GA
One version: https://www.youtube.com/watch?v=HNeY_Vge5gsDavid Vizard has a design using what looks similar to a hollowed out cat. Exhaust pipe protrudes into hollow chamber by a couple inches, exhaust goes out end of the pipe expands into the chamber and is somewhat restricted from being pulled backwards into the pipe. Operating principle is it stops reversion flow of exhaust gasses back into the cylinder by trapping some of it from being able to backflow. From what I am reading circle track cars that are limited to stock cylinder heads and 2bbls are supposedly making more part throttle torque but losing no top end.
[Re: 360view]
#2915909
04/27/21 09:56 PM
04/27/21 09:56 PM
Posts: 18,677 Fresno, CA
Jim_Lusk
Fresno, CA
Magnum V8s have Chrysler designed and factory standard anti-reversion lips at both the exhaust flange and intake runner to cylinder head.
“Step Header Pipes” are the anti-reversion design feature considered to be most effective.
How many inches away a catalytic converter or muffler is placed from the exhaust valve seat does have an effect on Torque and Volumetric Efficiency of Cylinder filling at a particular rpm.
If you have a single cylinder engine running at a set rpm ( think portable generator) the length of exhaust pipe to either muffler entrance or pipe end can have a very noticeable effect on horsepower, but you rarely see this taken advantage of because the pipe needs to be long. Most such generators have the shortest pipe to a short muffler for cost and space reasons.
There are programs that computer model exhaust systems (PIPES) or Engine Analyser from Performance Trends.
If you were lucky enough to take High School physics in the 1970s, the amazing PSSC Physics course had water tables were you could see with your own eyes waves hitting various shaped barriers. There is the famous “two slit” experiment where a broad parallel wave hits a wall with two narrow slits, tiny new waves emerge from the slits and then “reinforce” to higher wave top areas and “interfere” to spots where the wave height disappear. Today, sadly, high school students never set up such experiments with their hands and witness results with their eyes. They are lucky to even see a video.
If you are a white water rafter with physics trained eyes you see reversion waves frequently.
I remember the wave table in high school physics (1977/78). We had one of the most fascinating teachers, as well. A truly remarkable man with a wicked sense of humor (while I don't have access at the moment, he can be seen on the intro to a page that I have on Facebook, KBUL, as he also ran the radio/tv production class). My lab partners were outstanding, as well. Still have semi-regular contact with two of the three. Absolutely great memories.
