S60 SPRING PADS
#2915067
04/26/21 09:26 AM
04/26/21 09:26 AM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
hi, ordering new dana S60, should I have spring saddles welded on 90* from cover or add 1-2 degrees for pinion angle? looking for 5* nose down when done. hate to use pinion shims, or wait until car together
gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: S60 SPRING PADS
[Re: DAYCLONA]
#2915327
04/26/21 04:53 PM
04/26/21 04:53 PM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
Best bet is to install it in the car, mock up ride height/weight/etc, then tack the perches where you want them, remove, finish weld, you'll be glad you did... Agreed, Order some spring perches from Calvert Racing as opposed to using the stock style ones. If you run cal tracs there is extra load on them and they can roll over or collapse. If you have enough power for a Dana a set of those wouldn't be a bad idea cal tracs or not.
68 Barracuda Formula S 340
Re: S60 SPRING PADS
[Re: cudaman1969]
#2916117
04/28/21 01:35 PM
04/28/21 01:35 PM
440lebaron
westerly, ri. usa
HI if I tack right side preload will be on left , if tack left side preload will be on right ?????? gary
