So, from the best you can tell, one side is 0.005" different piston to deck than the other side, right?
That isn't "bad", but when you pay to square the decks, I would expect better.
On another note, I am getting ready to order an ATI super damper for my B1 572 CID build. Is yours the regular 917122E part for the OEM pulley bolt pattern and timing cover?
Or the version for the Indy cast timing cover? Just wondering if the AMP belt drive system would benefit from one or the other.
BTW, if you want to borrow the puller plate I made for the AMP crank pulley, just PM me and I will send it to you for trial and error fits....
That pulley has 3 threaded holes 6mm x 1.0 lead metric...
