Need help from the greatest minds on Moparts
#2914265
04/24/21 11:30 AM
04/24/21 11:30 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Considering that I'm a member here the title may not be saying much. Maybe I'm just too close to the problem so I'll pick your minds on this. Lake Kevin Abatement has reached Phase II. I'm making progress on the back yard flood control. I need a good way to terminate my pump discharge line at the sidewalk out front. My pump drains 5 residential lots. What is the best long term cost effective surface discharge? I'd prefer something more attractive than the PVC pipe laying on the grass. Idea killers: French drain will not work. Flooded area is lower than the discharge area. 2" diameter discharge will flow so fast it will strip away vegetation and soil. I do not have available power to add a second discharge pump at the sidewalk. Leach field is not an option. Dry well is not an option. Soil expansion and contraction means lots of ground movement. Here's the current setup: 43 gallon per minute pump with two inch discharge pipe. Pump is on the back wall of the shop. Pump discharge pipe lays on the surface. 2" PVC pipe makes the corner at the back of the house and runs 25 feet with a rise of a few inches before transitioning to 3" pipe for the slight downhill run out. Step up in pipe size for the downhill portion eases the load on the pump. 3" pipe grate will flow as much as a 2" open pipe and still acts as a barrier for small critters. Discharge pipe runs 8 feet sideways then 97 feet to the sidewalk. Here's the constraints: Back yard is lower than the street. Curb on the street is 4" tall. Sidewalk before the curb is 2" thick. Low discharge at curb means street water would backflow into my discharge line. Front lawn is flat and level with the sidewalk. Shallow elevation change means an underground pipe with a surface discharge has a lot of water filled pipe when flow stops. Black clay turns to gumbo mud when wet so complete evacuation is desired. The attached photo shows the known drain area. Yellow oval is the pump location. White discharge pipe can be seen leading to the sidewalk. The portion not seen in the photo is drawn in yellow.
Re: Need help from the greatest minds on Moparts
[Re: feets]
#2914275
04/24/21 11:38 AM
04/24/21 11:38 AM
feets
Senior Management
Senior Management
Irving, TX
Here's a view of the discharge line and discharge.
[Re: Fat_Mike]
#2914304
04/24/21 12:52 PM
04/24/21 12:52 PM
feets
Senior Management
Senior Management
Irving, TX
What's in the back yards of these 4 houses? Is bringing in sandy soil to raise the lake floor an option? I'm not paying to landscape 6 houses.
[Re: Alaskan_TA]
#2914305
04/24/21 12:55 PM
04/24/21 12:55 PM
feets
Senior Management
Senior Management
Irving, TX
Look into a one way valve / back flow prevention unit to prevent possible back flow from the street. I can't get under the sidewalk and out the curb without leaving a low spot in the pipe. The opening would be prone to plugging from debris, some of which could be pushed up against the back flow valve and hold it closed.
[Re: 360view]
#2914308
04/24/21 01:01 PM
04/24/21 01:01 PM
feets
Senior Management
Senior Management
Irving, TX
Approximately where on your street is the first street stormwater drain, and is there a buried stormwater drain pipe on your side?
HA! No storm drains on my street. Water must run past two more homes and turn a corner to find a storm drain. Do you have any legal liability worries about how the drain discharge is going across the public sidewalk? The city did not mention any since that is supposed to be the natural path of flow. How are you presently handling your roof gutter downspout discharges? I am installing catch basins under the downspouts and routing them to the pump. Once I get a stand alone electric service to my shop I'll have the power to add a second yard pump on the other side of the house to handle flow over there.
Re: Need help from anyone
[Re: feets]
#2914322
04/24/21 01:28 PM
04/24/21 01:28 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I can't get under the sidewalk and out the curb without leaving a low spot in the pipe. The opening would be prone to plugging from debris, some of which could be pushed up against the back flow valve and hold it closed. Install it at the curb. That way if it is blocked for any reason, you can clear it from the end.
[Re: Alaskan_TA]
#2914334
04/24/21 01:46 PM
04/24/21 01:46 PM
feets
Senior Management
Senior Management
Irving, TX
I can't get under the sidewalk and out the curb without leaving a low spot in the pipe. The opening would be prone to plugging from debris, some of which could be pushed up against the back flow valve and hold it closed. Install it at the curb. That way if it is blocked for any reason, you can clear it from the end. The top of the sidewalk is slightly lower than the curb so you have to start at least two inches down. Not much room to work with.
[Re: roadrunninMark]
#2914338
04/24/21 01:52 PM
04/24/21 01:52 PM
feets
Senior Management
Senior Management
Irving, TX
Thinking of a different angle, but can you donate/trade/sell the water off to a local farmer or ?? Pump the water into a big tank and they could come get it. Unique idea. However, the DFW metroplex is roughly the size of New Hampshire and I live smack dab in the middle of it. It takes an hour or more to drive to farm/ranch land and I don't have room for water storage. We'd be really hootched if a tank that big sprang a leak. After a 45 minute storm my pump ran for a solid 5 hours. That's not counting the cycle times before it was overrun and after it caught up. That 5 hours equates to over 13,000 gallons of water.
[Re: feets]
#2914352
04/24/21 02:31 PM
04/24/21 02:31 PM
Posts: 12,422 Warren, MI
71TA
Warren, MI
What's in the back yards of these 4 houses? Is bringing in sandy soil to raise the lake floor an option? I'm not paying to landscape 6 houses. The middle of our block where our house is WAS the low spot. We asked the city for help. They said it was a "landscaping problem". I SHOWED THEM what a landscaping problem was and raised our yard 2 FEET. That was expensive and a BUNCH of trucks! Now the neighbors on each side have a lake a couple times a year. We asked if they wanted to "go in on it" to disperse the water equally. Guess who's kicking themselves. "WATER ALWAYS WINS!" late Glenn Haege (home handyman radio show here in Detroit) And we are gonna put an offer on a nice house on an island in the lake to the east of Detroit. An Army Corp of Engineers website has an online interactive map. It shows if water levels rise 2ft the whole island is underwater. Luckily the lake is at historic levels so I hope it can only get better not worse. At 58 if we can enjoy it for 20 years we'll do good
[Re: 71TA]
#2914367
04/24/21 03:26 PM
04/24/21 03:26 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
can you just fill your yard some and let the other neighbors worry about kevin?
[Re: feets]
#2914375
04/24/21 03:50 PM
04/24/21 03:50 PM
Posts: 10,126 A Red State
SNK-EYZ
A Red State
The idea of catching and storing the water made me think of what a buddy did at his house.
He's rural and so there are no fire hydrants anywhere near his place.
He had a giant cistern (sp.) (aka underground water tank) built and built one of his patios over it. All the downspouts and paved areas drain into it. I think it hold something like 60,000 gallons and it's there for the fire department to drop a hose into if there's ever a fire.
Admittedly his house did cost millions to built, from what I've been told $14 million.
Storing water for watering plants for when there are drought is a thought.
I know it's had to think about droughts when you currently getting flooded.
[Re: HotRodDave]
#2914397
04/24/21 04:25 PM
04/24/21 04:25 PM
feets
Senior Management
Senior Management
Irving, TX
can you just fill your yard some and let the other neighbors worry about kevin? The neighbors let their yards flood and it caused all sorts of problems. I dumped $30,000 on home repairs a year ago, largely due to foundation issues. That was the second lift and repair in the last 20 years. Black clay is evil. The neighbor behind me (white car in driveway) filled their yard. It now runs off into mine. I have a catch basin at the corner of their yard to deal with it. My other two catch basins are at the fence with the other neighbor behind me. She's elderly and I haven't see her in the back yard in more than 10 years. Her yard has standing water. It soaks through the clay and percolates up into my catch basins. I can actually watch the water bubble in. It hasn't rained since yesterday afternoon and my pump is still cycling every few minutes to remove water leaching in from the clay.
