Re: Indy Heads back from porting, Guess on HP/ET Gain?
[Re: 440Jim]
#2913625
04/22/21 08:25 PM
04/22/21 08:25 PM
Posts: 31,105 Oregon
AndyF
More stall might be a good idea but the stall speed will increase naturally from the extra torque so I'd try it first.
I agree with the trend, so the converter company will make use of the extra data. But I still think that "small 446" CID and long 284 deg @.050 duration will want high 5 grand stall speed for best perf. Now I am coming from 500+ CID experience... I agree with you but I'm wondering if that 446 engine really needs 284 duration. My guess is that the car would be faster with a smaller cam. The OP might not want to spin that 446 high enough to make use of the 284. If I was building a 446 with those heads and a solid roller I'd probably be 10 degrees smaller if not more. My 470 ran best with 264/268 and that was with MW heads and a ported intake. I didn't have as much compression so with more compression the cam can be a bit bigger. If the cam was smaller then the torque converter might be okay as is. I just ran a 565 inch BB Chevy on the dyno with a 284 cam. It was a full race setup with 14:1 compression, CNC heads, Dart block, etc. It made 900 hp at 6500 rpm. Makes me think the OP's cam is too big.....
[Re: Moparrob68]
#2913728
04/23/21 12:28 AM
04/23/21 12:28 AM
Posts: 4,648 aotearoa
rebel
aotearoa
Rebel, are you spinning that 455 to 8000 with a stock block? I've been trying to keep the rpm under 7000 to make the tall fill,Hughes girdled stock 440 live. No, I'm using a low deck Maxx block. I have a 512 with a stock block I rev to 7k, but has a BCR girdle kit to keep it together.
[Re: Moparrob68]
#2913786
04/23/21 09:43 AM
04/23/21 09:43 AM
Posts: 16,934 NC
440Jim
NC
I sent the old Reed cam out to Bullet and had it reground wit 276*/279* dur .670 lift with 1.6 rocker ratio. Do you think that cam would perform better in this combo or will the ported heads like the 284 cam.
I hate to say change too many things at once (heads and cam), but since you want to keep the RPM below 7000; I think the 276*/279* dur .670 lift would be a better fit. More torque to improve the sixty foot time and work with the existing "low" stall converter better. Still think a high 5k converter is the right thing to have at the end of the day (month, year, etc.). It has been a long time since I raced less than 493 CID, but that sixty foot seems slow for a 2950 lb car with a 3-speed transmission. Or is it a PG with 1.76/1.80 first gear?
[Re: Moparrob68]
#2913792
04/23/21 09:51 AM
04/23/21 09:51 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Quite simply, I wouldn't do a thing. I'd go run the car, get a timeslip, then, the incrementals on that slip, will tell you everything you want/need to know. You can then adjust with data. This is the old ask 100 people, and you'll get 130 answers.I am sure you will need to make changes, but I wouldn't just guess.
RIP Monte Smith
[Re: CompWedgeEngines]
#2913797
04/23/21 10:12 AM
04/23/21 10:12 AM
Posts: 4,103 Yes
sixpakdodge
Yes
Quite simply, I wouldn't do a thing. I'd go run the car, get a timeslip, then, the incrementals on that slip, will tell you everything you want/need to know. You can then adjust with data. This is the old ask 100 people, and you'll get 130 answers.I am sure you will need to make changes, but I wouldn't just guess. I agree 100%. I personally don't see the need for more converter or more gear. It's a bracket car, no sense in killing the motor with rpm that you don't have to. I am sure it will run quite well.
#2913824
04/23/21 11:16 AM
04/23/21 11:16 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
[Re: justinp61]
#2913905
04/23/21 01:04 PM
04/23/21 01:04 PM
Posts: 4,103 Yes
sixpakdodge
Yes
![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) A buddy of mine runs a 499 or 500" wedge in a tube chassis bracket car, smallish solid roller with good springs. It runs 5.70's or so shifting at 6400 and lives long trouble free lives. Exactly. The 528 in my Omni-Charger went 5.65-5.70 shifting at the same rpm. It has -1's, bowl ported (330@ .700), .693 roller, 1.76 Glide, and a 4.10 gear. Car is 2500 with me in it. I can't remember the Duration or Cam CL, but it is a fairly mild grind.
[Re: 440Jim]
#2913937
04/23/21 02:16 PM
04/23/21 02:16 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d put it back together with the Bullet cam.
I built a RB451 several years ago....... 13:1, SR heads with MW openings that flowed in the 340’s, port matched 440-3, 272@.050/.650 lift cam, 1.5 rockers. Made peak tq at 5500, peak hp at 7200.
