70 ebody front door glass rear regulator mounting hardware #2913146
04/21/21 08:27 PM
04/21/21 08:27 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
i found the front ones [ they are phillips head screws] that screw into the nylon snaps,... but the rear one is obv a bolt of some kind.. also was there a plastic/fiber like washer between regulator lower arm and glass? i know there was a small rubber insulator inside it
to make sure glass cannot hit the mounting bolt edge... so anyone have an idea on what parts i need? ...pics? thanks
SEE PIC..round hole at lower end rear of regulator is the access hole for the bolt/? i need..
Re: 70 ebody front door glass rear regulator mounting hardware [Re: ph23vo] #2913548
04/22/21 06:00 PM
04/22/21 06:00 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 70 ebody front door glass rear regulator mounting hardware [Re: 71TA] #2913549
04/22/21 06:03 PM
04/22/21 06:03 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
those are the gaskets its already has.. i need the bolt?.. that connects it to the regulator..
Re: 70 ebody front door glass rear regulator mounting hardware [Re: ph23vo] #2914076
04/23/21 08:39 PM
04/23/21 08:39 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
found one original washer sitting inside drivers door...just used 2 bolts that fit and had a washer that was able to go inside lower track... glass is in!
