Dana 60 Identification #2912329
04/20/21 02:10 PM
04/20/21 02:10 PM
Madison
CudaKidFam Offline OP
Madison
Hello all! New to the forums. Need help identifying a Dana 60.
Bought this about 20 years ago from Ultimate Rides in El Paso, TX (I think that's where I got it). I had planned to put it in a 1970 Hemi Cuda clone. Haven't touched it in all this time until yesterday, and now I'm trying to decide whether to sell it, use it, whatever. Questions arose pretty quick about what this thing actually is. The BOM numbers on the back of the RH axle do not match any database I can find. But there are clues that point to this being an E-Body Dana. Here's what I know:
1. Wheel bolt pattern is Mopar.
2. Bumper on snubber plate (if it's the original) has Mopar on it.
3. Perch to perch measurement is 46".
4. Tag on exterior differential housing reads "307-69."
5. Ring gear is dated 7-22-69 with 4:10 ratio.
6. The number "60" is on the exterior in two places.
7. Numbers on rear of axle read "2 26 0A1" and "27013 2X".
Pictures attached. Can anyone tell me exactly what this thing is? Many thanks.
Re: Dana 60 Identification [Re: CudaKidFam] #2912366
04/20/21 03:08 PM
04/20/21 03:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
46" pad width makes it an E-body. '69 date codes make it a '70 model year.
Re: Dana 60 Identification [Re: John_Kunkel] #2912367
04/20/21 03:10 PM
04/20/21 03:10 PM
BDW Offline
BDW  Offline
As mentioned, doesn't seem to be factory part, maybe over the counter DC part?
Re: Dana 60 Identification [Re: BDW] #2912390
04/20/21 04:02 PM
04/20/21 04:02 PM
Madison
Madison
How about the inside? I was told this is not a sure grip.
Re: Dana 60 Identification [Re: CudaKidFam] #2912520
04/20/21 07:06 PM
04/20/21 07:06 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I don't see any clutch packs or springs ?,maybe from a truck or van where any the same dimensions.
Re: Dana 60 Identification [Re: 71GTX471] #2912538
04/20/21 07:26 PM
04/20/21 07:26 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Trucks should have had the spring pads on top of the axle because most had the axle under the springs.
Mopar means never say never.
Maybe it was a warranty replacement axle for one that was defective.
Re: Dana 60 Identification [Re: poorboy] #2912585
04/20/21 08:32 PM
04/20/21 08:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quote
that was true with all of the big 3 back in the day. Might have had something to do with the union contract clause that stated if the line was shut down due to a parts shortage the workers went home with full pay for the remainder of the day wink
Quote
Possibly, but one would think the owner would have noted the one wheel squealer whistling
Dimensionally it appears to be an e body Dana. The open differential and BOM #'s are puzzling. possibly an over the counter replacement as mentioned. I am not 100% sure on the truck pads being on the top in all applications.
Hopefully someone else will chime in, Where's Dr. Diff ?? wink
Re: Dana 60 Identification [Re: TJP] #2912605
04/20/21 08:50 PM
04/20/21 08:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Dana 60 Identification [Re: TJP] #2912657
04/20/21 10:07 PM
04/20/21 10:07 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
This is my take. It is a over the counter bare housing. Therefore no BOM that makes sense. Being a replacement housing it has a number that no doubt correlates to Dana some way. Being bare there was no assembly of additional parts so no BOM.
Re: Dana 60 Identification [Re: NITROUSN] #2912723
04/21/21 01:56 AM
04/21/21 01:56 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I'm not an expert on the BOM numbers.
I can tell you the housing was made in 1970 for an E-body application. It has a 1971 spec Mopar passenger car 35 spline Track-Lock Sure-grip with a thrust button and an older set of gears someone installed.
I don't see a second set of numbers normally stamped on the housing, which corresponds to when the rear was assembled.
Re: Dana 60 Identification [Re: DoctorDiff] #2912750
04/21/21 07:56 AM
04/21/21 07:56 AM
Madison
Madison
Doctor Diff,
Appreciate the info. I'm a novice, especially when it comes to rear ends, so bear with me, please. How were you able to tell the "1971 spec Mopar passenger car 35 spline Track-Lock Sure-grip with a thrust button and an older set of gears someone installed" from one picture? As I said, someone else looked at the same pic and said it was not a sure grip. If the housing is from 1970, what did you see that made you say it was a 1971 set up (but with the older ring gear)? Is there anything wrong with what you see, in other words, could I have someone go through it and put new seals, brakes, etc., and install it with no problem?
Thanks!
Re: Dana 60 Identification [Re: CudaKidFam] #2912765
04/21/21 08:50 AM
04/21/21 08:50 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Mopar did sell some over the counter Dana. I have a friend that bought one. It’s a 44” wide version.
Re: Dana 60 Identification [Re: fastmark] #2912785
04/21/21 09:24 AM
04/21/21 09:24 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
as I recall direct connection sold 2 dana 60's 44" 42" suregrip/posi, spring pads were shipped loose or not at all?
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Dana 60 Identification [Re: 440lebaron] #2912812
04/21/21 11:03 AM
04/21/21 11:03 AM
Ontario Canada
ldm Offline
ldm  Offline
Ontario Canada
From the 1983 Direct Connection catalogue for 9 3/4 Dana:
P4120694 5:12 - 52" housing, power lock
P4120693 5:38 - 44" housing, power lock
Re: Dana 60 Identification [Re: CudaKidFam] #2913419
04/22/21 01:39 PM
04/22/21 01:39 PM
VA
dragon slayer Offline
VA
Doctor Diff,
Thanks!
From 66-70 the unit was powr-lok which is a 2 piece case held together with 8 bolts had 4 pinion gears. The 71 unit was changed to track-loc with solid case and the open window with just 2 pinion gears on a shaft. Axle spline started as 23T and moved to 35 after 1969. Sometime during 70 production. Yours is an open window 2 pinion case.
Re: Dana 60 Identification [Re: dragon slayer] #2913455
04/22/21 02:40 PM
04/22/21 02:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The difference. Powr-Lok on right.
Re: Dana 60 Identification [Re: John_Kunkel] #2913619
04/22/21 08:21 PM
04/22/21 08:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
To avoid any confusion, the Power Lok is showing on the bottom of your post on my screen wink
beer
Re: Dana 60 Identification [Re: TJP] #2913628
04/22/21 08:31 PM
04/22/21 08:31 PM
Madison
Madison
Thanks much to all of you who commented. I feel much better now. The funky numbers on the axle had me wondering if I had been taken 20 years ago when I bought this thing. I obviously didn't know enough about Danas back then to ask the right questions, and those numbers, especially the lack of the usual BOM numbers, gave me concern in the here and now. But now that I've cracked it open, and you guys have confirmed it's the real deal, well, all is good now.
Thanks again.
Re: Dana 60 Identification [Re: CudaKidFam] #2913874
04/23/21 12:27 PM
04/23/21 12:27 PM
central il.
second 70 Offline
second 70  Offline
central il.
If you're building a decent HP hemi the trac-lock is a lot weaker than a power-lock. If I remember Dr. Diff said it would last @ 400 HP, power lock 600HP, and the S trac I bought from him should handle 1,000 HP.
Re: Dana 60 Identification [Re: second 70] #2913999
04/23/21 04:55 PM
04/23/21 04:55 PM
Madison
Madison
The Track-lock can handle only 400HP?? If that's the case, why would the factory put it behind a 71 Hemi at 425HP?
