Re: Nitrogen filled tires increase mileage ?
[Re: DPelletier]
#29142
08/02/06 03:38 PM
08/02/06 03:38 PM
Posts: 1,329 NC
DCM71cuda
NC
Nascar guys would use N2 in the tires because it would have the same effect all the time. In other words, if you fill the tire to 30 psi with air [cold], and it heats up to 180 during a run, what is the pressure at that point with the elevated temperature? Depending upon the amount of N2, O2, CO2, etc, that could vary. If you are using N2, it should be the same amount of change in pressure every time for a given temperature rise.
[Re: DCM71cuda]
#29143
08/02/06 04:08 PM
08/02/06 04:08 PM
Posts: 4,866 N. of 8mile, S. of heaven
Spike
Go Blue!!
Go Blue!!
Local tire store is promoting the heck out of nitro filled tires. Belle tire Click on the Nitro Nize and see how much $$$ you'll save!!! Give them credit for making it sound like the next best thing since O2 itself.
Post deleted by Defbob
[Re: 68HemiB]
#29148
08/02/06 07:45 PM
08/02/06 07:45 PM
[Re: MikeP]
#29149
08/02/06 08:17 PM
08/02/06 08:17 PM
Nascar use's it.....They tweak in 1/2lb adjustments(critcal long run adjustment) so the more stable the inflation gas the better......
I worked on on a Busch North team (now East Series) for 2 yrs in Nascar. Couple of races I was responsible for tires.
Nitrogen is used because it's expansion is much more controllable than using regular air. With compressed air from a tank, you have moisture that gets placed in the tires. When the tire heats up, the moisture expands at a diffrent rate than the air, so it made adjusting tough. This is also why tires are installed dry (no soapy water), they found out that some tires were exploding due to the water inside the tire turning to steam and blowing the tire apart.
As for using nitrogen in the air guns, it's not convenience, it's necessity. Since nitrogen is denser than air, you get much more volume of gas going thru the gun when removing lug nuts. More gas means faster rotational rate. Faster rotational rate means nuts get loosened faster.
#29150
08/02/06 10:27 PM
08/02/06 10:27 PM
Posts: 3,110 SC
V194
SC
According to the ideal gas law (pV = nRT) there is no difference in pressure rise of the different gases given a constant mass and volume.
oh, oh, I know this one!
6.022 x 10^23
What do I win?
(It's been about 30 years since my college chem class, and you have no idea how little I get to use stuff like this.)
Hey, that's Avogadro's Number! One of the few things I still remember from Chem class.
Yep Just remember your ABC's Avogadro's Number Boyle's Law Charles' Law
Post deleted by moparts
#29151
08/02/06 10:44 PM
08/02/06 10:44 PM
[Re: DUFFMAN]
#29157
08/03/06 09:29 PM
08/03/06 09:29 PM
Wow, I don't even know where to start. You need to read about Boyle's Law and learn a little about fluid dynamics.
Little far off? Me just knows what I was told.. I leave all the geeky E=MC2 to the pocket protector types..
[Re: shanker]
#29158
08/04/06 11:15 PM
08/04/06 11:15 PM
Posts: 3,160 L.I. N.Y. Hemi Street
HemiGreg
I wonder if Helium would yield abother 1mpg over that?
Here is the deal, Nitrogen makes up 85% of our atmosphere, the air compressor that is used to fill tires up, is compressing 85% nitrogen as it is, that news channel is full of it. There was a thread on this a while back
Wrong---- Atmospheric air is at best 80% N2, 20% oxygen and miniscule amounts of everything else the only place you will see 85% n2 is on top of 6-8000 ft elevation and even then theres more He and H cause the molecules are so small and light gravity dont pull em down- see your perodic table of elements, I got one hangs in front of me all night here at work. N2 and argone are best for intermoleculr space and resisting heat expansion thats why its put in double plane windows to avoid heat conduction. but as a scientist i cant go along with it inproving milege beyond .10% max as the expansion coefficient will not mathmatically work out unless the tire has a volumetric capacity of over 10 cubic feet.
now on the football nut, I filled a basket ball with 99.9999%pute Hydrogen which has morelift than Helium dropped both from my roof (25feet) off the same tilted board and the H2 ball bounced 10-12" higher after 10 trials, it does work, but most guys cant get 5-9s Hydroged. isnt chemestry and physics great
#29159
08/05/06 02:46 AM
08/05/06 02:46 AM
Posts: 27,480 So Cal
autoxcuda
So Cal
Local news article claimed 1-1.5 mpg improvement. Anyone here tried it ?
Total BS.
When you just fill a tire with nitrogen it's not 100 % nitrogen in it. There is still regualer air in there. Anyways the expansion of diameter of the tire while hot is mostly a fuction of the humidity of gas trapped in a tire.
I crew on a very competitive local NASCAR crew. We watch the diameter growth of tire with respect to tempurature. Just putting in nitrogen doesn't cut it. We need to PURGE the tires of all their gasses about 3-5 TIMES to get the humity down to 3-8%. We have a special tire air humidity guage to check this.
Now if the tire monkey that mounts your tires uses and bunch of soap and water to mount your tires, you have a bunch of humidity trapped in them.
Another advantage of filling a tire with Nitrogen is that the itsmolecules are thicker and bigger than air.. So if the tire has a slow leak it takes considerably longer for the tire to deflate.......
I don't buy that. Gas molecules thick or not can get by any leak.
If regular air expands more with heat than straight N2 then you would think that you get better mileage with regular air as the pressure builds and rolling resistance goes down.
That's a good point. I remember when honda offered the CRX HF (high efficiancy) model than had narrower tires with high recommended inflation pressures.
From what I understand it's out of convienence. They have pressurized nitrogen readily available and don't need to have a compressor. I'm not sure what they already use the nitrogen for, maybe someone else does?
Yes it is convenient. It's about the cheapest thing out of a tank and will run a air tools. And you can turn the pressure up more than a common compressor can pump out for those tricked out ported NASCAR air guns.
