Re: 360 Magnum Single Plane Spread bore Intake Manifold
[Re: Moparite]
#2911605
04/18/21 11:26 AM
04/18/21 11:26 AM
Posts: 14,592 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
P5007380, P5007380AB, P5249501 Single plane, magnum heads, carbureted...... came on some Magnum headed crate engines.
[Re: fast68plymouth]
#2911844
04/19/21 06:26 AM
04/19/21 06:26 AM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
P5007380, P5007380AB, P5249501 Single plane, magnum heads, carbureted...... came on some Magnum headed crate engines. Thanks, what are the differences between those 3 intakes?
[Re: LSP]
#2911854
04/19/21 06:53 AM
04/19/21 06:53 AM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I was told part of the delay with the release of the single plane TrickFlow intake was they wanted to make it so it could be used on LA or magnum engines but looking at the pictures I don’t think that plan worked out. The Speedmaster dual plane is set up that way but that intake sucks even after porting work.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
