Leaf spring metal bushing sleeve #2906411
04/04/21 06:27 PM
04/04/21 06:27 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
When you put in urethane spring eye bushings, you need to remove the old rubber bushing and the outer metal sleeve.
Is there a trick to doing this ?
I think I just invented the least fun method possible, I just beat the holy ****************** out of it.
But there must be a better way ?
Re: Leaf spring metal bushing sleeve [Re: hemienvy] #2906530
04/04/21 08:08 PM
04/04/21 08:08 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
I've used a press.
Mike.
Re: Leaf spring metal bushing sleeve [Re: hemienvy] #2906777
04/05/21 10:08 AM
04/05/21 10:08 AM
Trumussia
jcc Offline
jcc  Offline
Trumussia
Get a bigger hammer? eek grin
If you can't dazzle them with diamonds, don't waste your time, because nothing will
Re: Leaf spring metal bushing sleeve [Re: jcc] #2906847
04/05/21 11:45 AM
04/05/21 11:45 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Use a hot wrench on the inner sleeve. It will melt the rubber then you can push the sleeve and rubber out leaving the outer.
Carl Kessel
Re: Leaf spring metal bushing sleeve [Re: CKessel] #2906987
04/05/21 07:50 PM
04/05/21 07:50 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Long bolt with a large washer (that is smaller than the diameter of the bushing) on one side with a large socket on the other with a piece of flat stock and a nut. Tighten the nut and draw the bushing through into the socket. Not a very good description, but I used this setup to replace a set of spring bushings when doing a Cal-Track install.
Re: Leaf spring metal bushing sleeve [Re: hemienvy] #2911261
04/17/21 10:40 AM
04/17/21 10:40 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
PB blaster and a press has served me well in the past. You also can saw a groove in the sleeve to reduce tension and then push it out.
