Re: Cooling a hard block engine
[Re: orangemonster]
#291095
04/17/09 03:13 PM
04/17/09 03:13 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
i would be more worried about oil temp. You will never be able to keep the oil cool with a full block of hardblock. I would think the water temp would be fine since all the cooling system has to deal with is the heads. You should never have a fully filled block on the street.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: orangemonster]
#291103
04/23/09 04:06 AM
04/23/09 04:06 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
wait...so, you forgot to take the thermometer to measure the temps? or you forgot what the temps were?
you SHOULD have a huge difference in the radiator hoses...one is hot, coming out of the engine, the other should be cold, going back into the engine.
my 440source aluminum pump housing is working fine for me.
**Photobucket sucks**
[Re: FuryUs]
#291105
04/23/09 10:41 AM
04/23/09 10:41 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Not to Hi-jack the tread but it seems thier are some people on here that understands engine temp. I have to run a Sho-Gun water manifold on my engine because of the vacum pump and mech. fuel pump. The only place I can find to put the water temp. sending unit is on the side of the block in the block drain hole. Is this good enought to get a accuate or a lest close to accuate reading?THANKS
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#291106
04/23/09 11:56 AM
04/23/09 11:56 AM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
i think thats the best place yo put it .. i actually drill a hole between 1 and 3 for mine but just because i have the block filled..
[Re: 70Cuda383]
#291107
04/23/09 01:12 PM
04/23/09 01:12 PM
Posts: 845 Utah
orangemonster
super gas
super gas
Utah
This is what I did this morning,changed the oil,15-40 delo,7 qrts.Drained the rad and the block,ran water through them till it was all clear,then let it sit and did it again.Took the 160 stat out and took it apart and reinstalled it.Put in anti freeze and water,ran it for about 10 minutes in the driveway,temp was 150,without the cap on,I'm not seeing any circulation,stock rad.3 core.The mechanical temp is installed in the water pump.There is still a big diff in temp between the rad hoses.Would it be more consistant running a ristrictor instead of a stat?
