power brake vac #2910505
04/15/21 02:28 PM
04/15/21 02:28 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hi,
1975 b-body 400 race cam no specs yet, (drag race no street use) anybody run power brakes? hard pedal? switch to manual??
thanks
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: power brake vac [Re: 440lebaron] #2910564
04/15/21 04:55 PM
04/15/21 04:55 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Cam specs are somewhat irrelevant.
How much vacuum you have is, I've heard 17"/hg minimum.
If you have less than that there are things that can be done. Adding a vacuum pump is one. Going with manual brakes is another.
Since all my rides are manual brake setups it's not really an issue for me.
Re: power brake vac [Re: Sniper] #2910899
04/16/21 11:38 AM
04/16/21 11:38 AM
moparx Offline
moparx  Offline
then there is the question of a single diaphragm or a dual diaphragm booster, and the booster size.
disc brakes usually use a dual diaphragm booster, while drums use a single one, but if enough vacuum is produced with a pump, maybe a single unit booster would work ?
beer
Re: power brake vac [Re: moparx] #2910945
04/16/21 01:16 PM
04/16/21 01:16 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Originally Posted by moparx
then there is the question of a single diaphragm or a dual diaphragm booster, and the booster size. beer
This right there is a great point!
I have a dual-chamber booster on my Dippy coupe, the hydraulic flat tappet cam only pulls about 7" of vac, and it's dipped lower, right down to 5" at idle numerous times (mostly when I was tuning and trying a few things here and there), point being: my brakes have NEVER gone away!
This is with discs up front and drums at the back.
Re: power brake vac [Re: Diplomat360] #2911547
04/18/21 09:38 AM
04/18/21 09:38 AM
westerly, ri. usa
westerly, ri. usa
Thanks I'll try it as is , if I have a issue I'll add a pump
Re: power brake vac [Re: 440lebaron] #2911559
04/18/21 10:34 AM
04/18/21 10:34 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Re: power brake vac [Re: Moparite] #2911608
04/18/21 12:38 PM
04/18/21 12:38 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by Moparite
The booster is one big assed vacuum reservoir and neither helps if you don't have enough vacuum to begin with,
Re: power brake vac [Re: Sniper] #2912106
04/19/21 08:59 PM
04/19/21 08:59 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The idea behind the reservoir is that it will store the additional higher vacuum achieved while cruising at higher RPMs via a check valve. That higher vacuum will then be available at lower RPM's / vacuum. Might work in a marginal situation but I have had little success on customers cars so the pump gets my vote. I believe the reservoirs are more of a snake oil / band aid approach. but they are good at doing what they are marketed for, getting money from your wallet to the suppliers / manufacturers whistling twocents beer
