wrinkle paint / ease of cleaning #2909744
04/13/21 11:58 AM
04/13/21 11:58 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
How easy/difficult is it to keep wrinkle paint clean? I've never had it on an air cleaner or valve covers. I'm thinking about possibly using it on an exterior component to give it a custom look. I've never seen anyone use it on the exterior. Wondering if it would be a bear to keep clean.
Re: wrinkle paint / ease of cleaning [Re: burdar] #2909766
04/13/21 12:48 PM
04/13/21 12:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Soft brush, soap & water should do it.
Don't get wax on it, but tire/plastic protectant - as in ArmorAll, 303, etc - will make it easier to keep clean.
I wouldn't recommend it (or bedliner) for areas that will get muddy, like lower body areas.
That takes more aggressive cleaning.
Re: wrinkle paint / ease of cleaning [Re: topside] #2909771
04/13/21 12:54 PM
04/13/21 12:54 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
House vac with soft brush extension.
Re: wrinkle paint / ease of cleaning [Re: Neil] #2909829
04/13/21 04:03 PM
04/13/21 04:03 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
After thinking about it a little more, I realized that Harley sells wrinkle paint so it must be used on exterior surfaces quite often. A Google search brought up lots of Harleys with wrinkle painted finishes.
I have a used set of 68 Dart GTS hood inserts. They were repainted badly in the past and the chrome is pitted. I'm thinking about doing something custom with them. My initial thought was to wrap the lower plates with carbon fiber vinyl. I bought some cheap stuff just to test but it doesn't stick to the sharp recessed corners and lifts. It does look good though from a distance with the upper section installed. That got me to thinking about wrinkle paint. The texture would hide the pitting in the chrome and might look cool. If it doesn't end up looking good, I'll buy the reproductions.
Here is what the QQ1 paint spray out looks like against the carbon fiber vinyl. Looks good but doesn't stick. Maybe the 3M stuff would conform and stick better?
