Fuel Pump MagneFuel Rebuild troubles...Need Help #2909032
04/11/21 12:14 PM
04/11/21 12:14 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
This fuel pump is killing me. Changed the seals twice, and it leaks out the weep hole and dumps the tank. Seal looked directional, so I flipped it, same issue......Last year it all started when the last day of racing, and it locked up in the stage lanes of round one....dumped the fuel tank in the lanes on hot pavement....Bearings were torched....Replaced everything and always the same issue..
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: Dragula] #2909041
04/11/21 12:43 PM
04/11/21 12:43 PM
AndyF Offline
AndyF  Offline
Get rid of it. We had one of those fuel pumps in the dyno room and it was a constant maintenance issue. Replaced with a new Holley EFI pump and the problems went away.
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: AndyF] #2909087
04/11/21 02:38 PM
04/11/21 02:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Could always send it back to Magnfuel t be rebuilt. They have done a coupe for me and never an issue or much cost involved. One went through a fire in the Cuda the other came with the stratus when I bought it. Both were perfect after that
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: Dragula] #2909152
04/11/21 05:04 PM
04/11/21 05:04 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My 275 did the same thing, it locked up at about 300' on a 1/8 mile pass. I completely rebuilt it and 6 months later it was leaking again. It now resides on the shelf and I reinstalled the billet black Holley pump. Its been fine for two years. All the internals in the magnafuel pump are made in china, there'll never be another one on any of my cars.
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: justinp61] #2909190
04/11/21 07:13 PM
04/11/21 07:13 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I just bought and installed the Magnafuel 300 pump late last year. While driving a couple days ago, i noticed it seemed louder than i remembered last year. After the 30 minute drive and once back home, I felt the pump. It was very hot, hot to the point it was uncomfortable to keep my hand on it. I called Magnafuel and asked if that was normal for the pump to be that hot. They told me to check it with a temp gun and it should not be over 140* and 130*-140* is normal. Also, not to run for more than 1.5 hours at a time without shutting it off. I don't like that as i street drive alot and this is looking like a very unreliable pump. When it breaks, i will be replacing with something different.
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: mopar dave] #2909205
04/11/21 08:05 PM
04/11/21 08:05 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Never understood why people spend such huge dollars on those things specifically, and huge overkill on fuel systems in general.
I got talked into( via peer pressure) taking a perfect working dead headed Holley black off a hard leaving legit 650 horse 9 sec street strip car, and put an expensive return style system/ much bigger pump on the car.
It didn't run a thousandth of a second better than it ran for years with the black. I am sure the black would have supported even more power, as long as it gets good steady voltage
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: B3422W5] #2909227
04/11/21 08:52 PM
04/11/21 08:52 PM
Dragula Offline OP
Dragula  Offline OP
Ok...So lets say I want to replace it, what else fits like it does? Had a feeling I needed a new pump. Was going to order a Magnafuel 300. An A1000 is my favorite, but I would have to replumb the whole car...
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: Dragula] #2909271
04/11/21 09:54 PM
04/11/21 09:54 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you guys know anyone getting rid of those junk BG400 pumps I know a guy that would be interested.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: pittsburghracer] #2909281
04/11/21 10:09 PM
04/11/21 10:09 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Wait, you guys run electric fuel pumps?!
runaway
'63 Dodge 330
11.19 @ 121 mph
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: Dragula] #2909287
04/11/21 10:15 PM
04/11/21 10:15 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
This is the Holley pump I have. https://www.holley.com/products/fue...bureted_electric_fuel_pumps/parts/12-150
I ran it a couple years on my 408 then replaced it with the magnafuel, very happy I didn't sell it. I've been 6.25 @ 110 with it and driven a bunch on the street. Heck I went 6.57 with a old Holley blue pump and a 3/8" line bent like the factory line, still have it too.
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: justinp61] #2909353
04/12/21 06:05 AM
04/12/21 06:05 AM
Dragula Offline OP
Dragula  Offline OP
Originally Posted by justinp61
This is the Holley pump I have. https://wororww.holley.com/products...bureted_electric_fuel_pumps/parts/12-150
One thing that confuses me.....Magnefuel 275gph rated for 750hp max, the 300 is rated at like 850hp and the Holley is 125gph and rated to 900hp...
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: Dragula] #2909356
04/12/21 06:48 AM
04/12/21 06:48 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Those ratings are completely worthless. You need the volume graphs from the vendor if you really want to calculate anything.
My Magnafuel gave me one hiccup in the six years I had it, performed flawlessly other than that. What filter do you have before the pump? Are the flange surfaces warped?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: A39Coronet] #2909359
04/12/21 07:30 AM
04/12/21 07:30 AM
Dragula Offline OP
Dragula  Offline OP
It has a built in filter right before the pump....I really do not want to buy another pump, and if I did, I want to go back to an A1000, but that means missing opening day, and re-plumbing the whole car.
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: Dragula] #2909384
04/12/21 09:23 AM
04/12/21 09:23 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Keep wondering when I’m going to be faced with fuel pump issues... my Holley volumax under the car still has overspray on it from when the car was painted in the early 90s.
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: J_BODY] #2909385
04/12/21 09:30 AM
04/12/21 09:30 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I think Don hit the nail on the head, is seems we overthink the fuel system a lot of times.
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: justinp61] #2909389
04/12/21 09:54 AM
04/12/21 09:54 AM
Dragula Offline OP
Dragula  Offline OP
I don't think I am over thinking it. I think I do not want to buy another Magnefuel based on the feedback here and have exactly the same failure in a year or two. I didn't realize so many others were having the same issue. Plus, I rebuilt it, and I seem to be missing somthing because its still leaking. And I will tell you what, having the pump fail is one thing, having fuel all over a hot car and pavement is another. It dumps the tank every time this happens.
So finding a suitable alternative is kinda my thinking at this point in the game, but I am not totally sure. When you look at flow numbers and rated HP and nothing makes sense when comparing manufacturers. What flow do I need to make sure 850hp is just fine? I know an A1000 will cover that, and at 4amps less current draw.....Its the only other BIG pump I have experience with. And it was so good, I sold my spare I had for almost 10 years. That style pump, just does not lend it self well to installing it in my Duster and its not just the price of the pump anymore.
So I will call Magnefuel today and see if they can save my butt....Or maybe we try an A2000 pump....Not sure at this point. This sucks and I am almost out of time.
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: Dragula] #2909394
04/12/21 10:04 AM
04/12/21 10:04 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Send me all those junk Magnafuels Ill take them off your hands.. AS for the best pumps out there call Weldon, the best stuff out there. Lots of price points as well.
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: Al_Alguire] #2909410
04/12/21 10:30 AM
04/12/21 10:30 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I agree. I was just on their site looking myself. If the Weldon is reliable enough for an airplane, i trust it on my street/strip car.
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: mopar dave] #2909416
04/12/21 10:42 AM
04/12/21 10:42 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have Weldon stuff on all the racecars now. Nice when you can run the fuel pressure low and not see a drop or bobble in the pressure anywhere. My car and my sons dragster are both over 3g's at the hit and pressure doesn't move at all.
Re: Fuel Pump MagneFuel Rebuild troubles...Need Help [Re: Dragula] #2909435
04/12/21 11:28 AM
04/12/21 11:28 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
What is the weight/ET/ MPH of the car making 850 horsepower
1.41 best 60 foot
6.60 at 103.90 1/8
