Ballast Resistor
#2908183
04/08/21 09:14 PM
04/08/21 09:14 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
‘85 truck. 318. Friend’s truck. Will not start after running a little bit. Ballast resistor is real hot. Resistor looks new. Can a door prong resistor be used in order to trouble shoot?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Ballast Resistor
[Re: Andrewh]
#2908203
04/08/21 09:46 PM
04/08/21 09:46 PM
dfsmopars
Kentucky
It’s getting super hot. Quickly. Plenty of fuel. Spark to and from distributor. New MSD Blaster coil. After truck sits for a little while it starts.
[Re: dfsmopars]
#2908229
04/08/21 11:29 PM
04/08/21 11:29 PM
Posts: 4,711 Moved to N.E. Tennessee
GomangoCuda
‘85 truck. 318. Friend’s truck. Will not start after running a little bit. Ballast resistor is real hot. Resistor looks new. Can a door prong resistor be used in order to trouble shoot? You lost me at "door prong resistor ".
[Re: GomangoCuda]
#2908304
04/09/21 05:18 AM
04/09/21 05:18 AM
dfsmopars
Kentucky
‘85 truck. 318. Friend’s truck. Will not start after running a little bit. Ballast resistor is real hot. Resistor looks new. Can a door prong resistor be used in order to trouble shoot? You lost me at "door prong resistor ". Yea I can see that. Four prong.
[Re: dragon slayer]
#2908429
04/09/21 02:40 PM
04/09/21 02:40 PM
GomangoCuda
What is the resistance on the ballast? So you added new coil and ballast get real hot. That means excessive current and possibly coil over heating. Need to check the wiring, and make sure the resistor meets the coil spec. Exactly . What ignition ecu, what coil and what resistor? They are designed to work together and you may have disrupted the combination with the Blaster coil. Different coils can have very different primary resistance. What works best on a CD ignition is probably very wrong on an Inductive ignition. If the total resistance of the coil and ballast resistor is too low the ECU life may suffer. If the ballast resistance is too low for the coil then coil life could suffer. If the total resistance of the coil and ballast is too high then spark strength will suffer. If everything works together they will have a very long life. Things tend to go sideways If you upset that ballance by changing a part to something inappropriate.
[Re: Andrewh]
#2908439
04/09/21 03:17 PM
04/09/21 03:17 PM
Posts: 8,392 Highland, MI.
Sunroofcuda
Highland, MI.
ballast is bypassed during start. so if it was the ballast you would expect it to start then die when you let off the key. Not necessarily true. I had a ballast resistor go bad years ago on a '71 Charger & it would start & run just fine, then just cut-out at very inconsistent intervals. OP, start it & then get out & wiggle the wires connecting to the BR - if it sparks & shuts off, then it's the BR.
[Re: Sunroofcuda]
#2908441
04/09/21 03:50 PM
04/09/21 03:50 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
ballast is bypassed during start. so if it was the ballast you would expect it to start then die when you let off the key. Not necessarily true. I had a ballast resistor go bad years ago on a '71 Charger & it would start & run just fine, then just cut-out at very inconsistent intervals. OP, start it & then get out & wiggle the wires connecting to the BR - if it sparks & shuts off, then it's the BR. I had one break!
[Re: NITROUSN]
#2908453
04/09/21 04:27 PM
04/09/21 04:27 PM
dfsmopars
Kentucky
It’s getting super hot. Quickly. Plenty of fuel. Spark to and from distributor. New MSD Blaster coil. After truck sits for a little while it starts. Does it have spark when it will not start??? It does have spark when it will not start.
[Re: dfsmopars]
#2908517
04/09/21 08:52 PM
04/09/21 08:52 PM
Posts: 18,406 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
It’s getting super hot. Quickly. Plenty of fuel. Spark to and from distributor. New MSD Blaster coil. After truck sits for a little while it starts. Does it have spark when it will not start??? It does have spark when it will not start. So if there is spark to the plugs you are either starved of fuel or flooded.
[Re: Sunroofcuda]
#2908549
04/09/21 10:49 PM
04/09/21 10:49 PM
Posts: 6,215 nowhere
Sniper
nowhere
ballast is bypassed during start. so if it was the ballast you would expect it to start then die when you let off the key. Not necessarily true. I had a ballast resistor go bad years ago on a '71 Charger & it would start & run just fine, then just cut-out at very inconsistent intervals. OP, start it & then get out & wiggle the wires connecting to the BR - if it sparks & shuts off, then it's the BR. The point was that the ballast is not used during start. So if it won;t start it's probably not the ballast. OP later does say that there is spark when it won't start so the issue probably isn't ignition related, unless the timing is way off. Jumped timing chain?
[Re: Sniper]
#2908565
04/09/21 11:27 PM
04/09/21 11:27 PM
dfsmopars
Kentucky
I think I got it a little closer tonight. I swapped out the coil with one with higher resistance. About where I would expect it around 1.5-2.0 ohms. Then the timing that was at about 5 degrees BTDC, I moved it to about 3-4 degrees ATDC. Then I noticed the starter motor was dragging just a tad after attempts to start the engine. I put a charger on the battery and it helped some. I at least could sort of repeat the failure and the ignition. It still has its moments where it does not want to start. So the next question I have is this- can the starter become weaker as it warms up? I can pour a cap full of fuel in the carb and it does not help the starting. I don’t think it is flooding because it is a 2V carb that I took off the shelf and it ran well when I put it on there. There is plenty of bad wiring under the hood. Some wiring has lost its insulation. So that stuff has to be cleaned up as well. About the BR, should I be able to hold it in my hand while the truck is running without feeling like I’m going to get burned. I think there are numerous issues working in according. It’s not there but I sa things tonight that encourages me that it will get there. Once it starts it is slick, smooth and responsive.
[Re: dragon slayer]
#2908640
04/10/21 09:03 AM
04/10/21 09:03 AM
Posts: 1,383 Az
69hemibeep
Az
A hot coil will mimic vaporlock. Shut it down after a drive and it won't start, let it cool and away you go again.
1969 Hemi Roadrunner 2nd owner
