Cuda 5.7 //////harness to Rally dash tach #2908054
04/08/21 03:07 PM
04/08/21 03:07 PM
Ohio
V
viperakron Offline OP
V
Ohio
Bought a running 73 Cuda with a Gen 3 5.7 conversion. It has an interface done on all the other gauges in the stock rally dash. Was told to buy a MSD 8910 tach conversion module. Anyone wired up stock tach to gen 3 harness? Looks like I've got a violet wire in the 5.7 harness that sends a tach signal. Is the 8910 the correct conversion piece? Can anyone help with what goes where to make it work.
Re: Cuda 5.7 //////harness to Rally dash tach [Re: viperakron] #2911577
04/18/21 11:35 AM
04/18/21 11:35 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
I am assuming this converts can-buss to conventional? Would need to do the same with the tach if that's what the msd does.
