Page 2 of 3 1 2 3
70-71 440 Carter AVS Carburetor #4740S [Re: Memongo] #2907550
04/07/21 01:30 AM
04/07/21 01:30 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
70-71 440 Carter AVS Carburetor #4740S. Used, $200 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Call Steve 810-629-1097
Holley 4777 650 Double Pumper Carburetor Manual Choke [Re: Memongo] #2907551
04/07/21 01:34 AM
04/07/21 01:34 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Holley 4777 650 Double Pumper Carburetor Manual Choke. Used, $150 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Note: Should be gone through and set up for your application.
Valve Cover Oil Fill Caps [Re: Memongo] #2907553
04/07/21 01:51 AM
04/07/21 01:51 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Valve Cover Oil Fill Caps. Used, $10 Each + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
1. FE 70-72 models
2. Not sure!
3. 73-74 model (came of my 73 Cuda)
4. Mopar Preformance Chrome New!
Note: Pick the one you want by photo 1-4
Oil Cap 1.jpg (1075 downloads)
Oil Cap 2.jpg (1079 downloads)
Oil Cap 3.jpg (1084 downloads)
Oil Cap Chrome.jpg (1076 downloads)
Electric Choke Thermostat 360 400 2 Or 4 Barrel [Re: Memongo] #2907555
04/07/21 01:54 AM
04/07/21 01:54 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Electric Choke Thermostat 360 400 2 Or 4 Barrel. Used, $20 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Big Block Timing Chain Cover [Re: Memongo] #2907559
04/07/21 02:30 AM
04/07/21 02:30 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Timing Chain Cover. Used, $40 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
62-74 Oil Pressure Sending Unit [Re: Memongo] #2907767
04/07/21 04:05 PM
04/07/21 04:05 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
62-74 Oil Pressure Sending Unit For Models With Warning Light. Used, $7.50 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Mopar Performance Ballast Resistor .25 Ohm NOS P2444641 [Re: Memongo] #2907768
04/07/21 04:13 PM
04/07/21 04:13 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Mopar Performance Ballast Resistor .25 Ohm NOS P2444641. New, $25 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Factory Water Pump To Fan Spacer [Re: Memongo] #2908068
04/08/21 03:39 PM
04/08/21 03:39 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Water Pump To Fan Spacer 1.25 in' Thick. Used $15 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Fan Spacer 1.25 in.jpg (886 downloads)
63-76 Temperature Sending Switch #2426458 [Re: Memongo] #2908070
04/08/21 03:42 PM
04/08/21 03:42 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
63-76 Temperature Sending Switch #2426458 Used $7.50 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
6 Pack Air Cleaner To Carburetor Gaskets NOS #3462205 [Re: Memongo] #2908297
04/09/21 03:47 AM
04/09/21 03:47 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
6 Pack Air Cleaner To Carburetor Gaskets NOS #3462205. New, All 3 For $30 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Accel Cap & Rotor Kit #8320 [Re: Memongo] #2908419
04/09/21 02:00 PM
04/09/21 02:00 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Accel Cap & Rotor Kit #8320 New, $25 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2908611
04/10/21 07:26 AM
04/10/21 07:26 AM
danville, IN USA
CHALLENGER_KEN Offline
danville, IN USA
1970 440 SIX PACK motor fresh rebuild 30 over new erson cam it has the correct balancer cast iron six pack intake and correct dated carbs that will need to be restored
The Vin number on the block is 0G180380
The build date of the block is11-17-69
The carb numbers are 4382,4376,4383 with build dates of 3149, 3189,3249 the carbs need rebuilt
The asking price is $7500.00
Contact Ken at 1-317-709-3625
Mopar Performance Big Block Crankshaft [Re: CHALLENGER_KEN] #2908682
04/10/21 10:35 AM
04/10/21 10:35 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a used Mopar Performance crankshaft. It has the same casting number as the1964 Max Wedge crankshaft. Casting number is 2463548 and very nice. There appears to be minimal wear. Journal specs measured are in one of the pictures . 8 bolt flange is drilled for a 4 speed and retains its pilot bearing.
Price is $500 plus shipping.
Email me at procketrichard@hotmail.com for more information or pictures.
RB Crank 1.jpg (954 downloads)
RB Crank 2.jpg (954 downloads)
RB Crank 4.jpg (951 downloads)
RB Crank 6.jpg (955 downloads)
440 block for sale [Re: moparts] #2908955
04/11/21 08:17 AM
04/11/21 08:17 AM
K
kielbasa Offline
kielbasa  Offline
K
440 block pulled from 1973 Imperial. Std bore, it does include all main caps. Asking $300
Located SE Wisconsin 53040 zip
Re: 440 block for sale [Re: kielbasa] #2909420
04/12/21 10:51 AM
04/12/21 10:51 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
MOPAR 383-440 MOTOR MOUNT BRACKETS, BLASTED/POWDER COATED, PERFECT
FIT B&E BODY CHALLENGER,CHARGER,GTX,ROADRUNNER, SATELLITE,BELVEDERE,CUDA$75 plus 15 usps insured/tracked medium priority mail box
cowgerwilliam035@gmail.com
383-440 001.JPG (749 downloads)
383-440 002.JPG (749 downloads)
383-440 005.JPG (749 downloads)
383-440 004.JPG (753 downloads)
Re: 440 block for sale [Re: Joesixpack] #2909421
04/12/21 10:55 AM
04/12/21 10:55 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
383-400-440 ENGINE MOUNTING PACKAGE
2 ORIGINAL MOPAR STEEL ENGINE MOUNTING BRACKETS,POWDER COATED
NEW MOUNTING HARDWARE(ORIGINAL FACTORY HARDWARE IS ALSO AVAIL.)
2 NORS USA MADE RUBBER MOTOR MOUNT INSULATORS
2 LONG BOLTS THAT ATTACH THE RUBBER INSULATOR TO THE K-FRAME
COMPLETE PACKAGE
ALSO CAN BE CALLED A CONVERSION KIT IF YOUR GOING FROM A 318 TO A BIG BLOCK
WILL FIT ALL 1966-1972 V8 K-FRAME EQUIPPED B-BODIES CHARGER,GTX,BELVEDERE,CORONET,ROADRUNNER
1970-1974 E-BODY CUDA&CHALLENGER
1966-1973 C-BODY FURY,POLARA,MONACO,300,NEW YORKER,IMPERIAL$160 plus $15 insured/tracked priority mail med flat rate box
440m 001.JPG (745 downloads)
440m 002.JPG (750 downloads)
440m 004.JPG (748 downloads)
440m 003.JPG (745 downloads)
Re: For Sale - Big Block Engine - spool mount [Re: moparts] #2909424
04/12/21 11:00 AM
04/12/21 11:00 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Factory spool mounts been in my wash tank, then blasted and then primered so they wouldn't rust.
Comes with new inserts mounts.
$75 Plus the ride from 64804
Moparlee
Re: Clutch Fan [Re: moparts] #2909759
04/13/21 12:41 PM
04/13/21 12:41 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
SOLD
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #2910268
04/14/21 09:31 PM
04/14/21 09:31 PM
God's Country Maryland
GODSCOUNTRY340 Offline
1967 383 HP engine, fresh rebuild with '72 440 heads (346) with bowl blend, pocket port & mild porting. Comp hyd. cam 470/270, std bore, std steel crank. Can see running on youtube, type in Detrick383 engine to watch, no more wondering if the engine you bought is ready to go, we show you it's ready to go. $4,300. Pick up in western Maryland. detrick12220@atlanticbb.bet[img]http://[/img] Carb not included in sale.
"NEW" Fitech Go EFI #30001 [Re: moparts] #2910556
04/15/21 04:37 PM
04/15/21 04:37 PM
Northwest Indiana
19Coronet66 Offline
19Coronet66  Offline
Northwest Indiana
NEW in the box Fitech Go EFI part number 30001. I never so much as broke the factory seal on the box to check everything out. Just been collecting parts and decided to go a different route. Click on the Jeg's link to find all the information regarding the kit. It's been sitting in a closet for at least one year. $775 plus shipping
https://www.jegs.com/i/FITech-Fuel-Injection/546/30001/10002/-1
PM if interested
Page 2 of 3 1 2 3
