Re: For Sale - Race Parts - 2nd Quarter
[Re: moparts]
#2906224
04/04/21 12:55 PM
04/04/21 12:55 PM
Posts: 1,114 Central Il.
jughed
Central Il.
Brand new Glasstek pin-on decklid/trunk lid for '70 Roadrunner, GTX, Satellite. Very light. $200. Local pickup only.
SPD CNC header flanges for Indy 572, or 600 series heads. Will also work with 345 CNCed 440-1s. Part # M88517. These are 1/2" thick, 2 1/4" ports. Nice set! $150 + shipping.
NIB Ohio Crankshaft aluminum rods. 7.1 length, .990 pin, 2.2 rod ends. $500 + shipping
***SOLD*** B/RB dual line aluminum oil pan with kickout, baffles, and oil return line bungs. Capacity and maker unknown, but looks to be a Charlie's pan. No leaks. Came with purchased motor but have no need for it.
can email more pics
Please PM
[Re: moparts]
#2906232
04/04/21 01:04 PM
04/04/21 01:04 PM
Posts: 2,798 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
SPD W8 1 7/8" tube Craftsman truck pattern mild steel flanges, will also work for W9 heads reduced to $175 shipped
PM me through Moparts or email mgray0918@verizon.net
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#2906236
04/04/21 01:06 PM
04/04/21 01:06 PM
Plumb Wired
Blue Ridge, VA
Used Bickel 1.250" x .095" 4130 chromoly four link bars, upper bars are 16.50" long, lower bars are 17.50" long, used Aurora 4130 chromoly rod ends (4ea. 3/4" RH, 5/8" hole, 2ea. 3/4" LH, 5/8" hole, 2ea. 3/4" LH, 1/2" hole), used NAS bolt kit for use with .250" brackets (new NAS lock nuts), four link bars have been glass beaded, scrotchbrited and wiped down with WD40, all rod ends and bolts have been cleaned, new from Bickel all components listed are $720 new, my price is $430 for all shipped, Paypal add 3%.
PM me through Moparts or email: mgray0918@verizon.net
RIP Monte Smith
[Re: Plumb Wired]
#2906237
04/04/21 01:07 PM
04/04/21 01:07 PM
Plumb Wired
Blue Ridge, VA
Used Brodix/Koffels B1-MC Valves, brand unknown: (6ea.) Intake - Titanium 2.400" OD x 5.500" OAL x 11/32" Stem (6ea.) Exhaust - Stainless 1.780" OD x 5.400" OAL x 11/32" Stem
$400 shipped + Paypal fees
email: mgray0918@verizon.net or pm me through Moparts
RIP Monte Smith
[Re: moparts]
#2906371
04/04/21 05:05 PM
04/04/21 05:05 PM
Posts: 28,220 Oregon
AndyF
Strange S60 for A body car. Rear assembly is 50.75 inches wide from rotor face to rotor face. Fit in my Duster with 15x10 Centerline wheels. The axle perches are 35.25 center to center which was the same as the frame rails in my Duster. The rear assembly has 35 spline axles, Detroit Locker differential, 4.10 gears, Ford Explorer disc brakes and a Strange U1598 chrome moly 1350 yoke. $1900 for complete assembly. PayPal or cash, PM me on the board. Best picked up, doubtful that I'll be able to ship.
I also have the matching driveshaft for sale. It is 3 inch chrome moly with forged 1350 ends. Driveshaft was built by Strange Engineering and is 44.5 inches long from center to center. $150 for the driveshaft.
[Re: moparts]
#2906456
04/04/21 06:50 PM
04/04/21 06:50 PM
Posts: 1,255 Way out in the sticks of Weste...
DusterDog
I have a pair of used Strange Engineering Hy-Tuff 35 spline axles, excellent condition. These came out of a friend's bracket car. They have 1/2 inch screw in studs (3 inch long), & bearings. One axle measures 22 1/2 inches from the back side of the retainer plate to the end of the splines, the other measures 23 1/2 inches. The splines are 3 1/4 long. Asking $250.00 for the pair plus actual shipping..
PM me here (1st choice), or e-mail me at duster doug at comcast dot net..
Thanks for the ad Moparts!!!
"I've upped my horsepower, so...... UP YOURS!!!"
[Re: moparts]
#2906597
04/04/21 11:01 PM
04/04/21 11:01 PM
Posts: 30 IL
83hurstguy
IL
1.81” stainless exhaust valves, stock length, 3/8” stem, they are new with zero miles, they were installed in heads but removed. I was told these were Mopar Performance, but I can’t confirm that. $80 shipped to lower 48.
[Re: 6PAX]
#2907215
04/06/21 11:19 AM
04/06/21 11:19 AM
Posts: 118 Texas
Chief
Texas
Pro Gram Center Main Caps/4 Bolt 200.00 were used on a 400 B Block. Can be line bored for a RB. ATI 8 inch Converter serial # C30020 7. Stall is approximately 4800 flash according to ATI Tech. It was ran on a 440, injected alcohol foot brake car. B&M Flexplate included. SOLDDedenbear Lightning Plus delay boxes 200.00 features a billet aluminum enclosure that keeps all of the precision circuitry protected. The small multi-functional units' can be every racers little helper! Summit 549.00. Total Seal 4.030 file fit moly ring set 150.00 All items are plus shipping. PM here or email dcovey1@hot.rr.com ![[Linked Image]](https://i.imgur.com/OosjNfS.jpg)
Dave Covey
Mopar Performance Small Block Pistons - New Incomplete Sets
[Re: Rocket]
#2908676
04/10/21 10:28 AM
04/10/21 10:28 AM
Posts: 690 CT
Rocket
CT
I have 12 new Mopar Performance forged flat top pistons and pins. There are 3 different part numbers. There is not one complete set. Here is what I have.
P4876976 – Quantity of 6. Specs are 4.060” bore & ~ 1.67” compression height. These pistons are for a 0.060” overbore 360 with the stock stroke crankshaft or a 0.020” overbore 340 using a 3.58 stroke crankshaft. Price for the 6 new forged pistons is $320 plus shipping.
P4876978 – Quantity of 4. Specs are 4.030” bore and ~ 1.67” compression height, These pistons are for a 0.030” overbore 360 with the stock stroke crankshaft Price for the 4 new forged pistons is $190 plus shipping.
P5007413 – Quantity of 2. Specs are 4.030” bore and ~ 1.47” compression height, These pistons are for a 0.030” overbore 360 with a 4.00” stroke crankshaft. Price for the 2 new forged pistons is $100 plus shipping.
Email me at procketrichard@hotmail.com with any questions or for more pictures on the pistons you are interested in.
Re: Mopar Performance Big Block Crankshaft
[Re: Rocket]
#2908803
04/10/21 06:11 PM
04/10/21 06:11 PM
Posts: 2,002 IL
furious70
IL
Lunati bracket master II cam Gently used, cam only. .480/.480 292/292 230/230 @.050. part # 00032. $75obo plus shipping.
70 Sport Fury 68 Charger 69 Coronet 72 RR
