Fuel With Ethanol Effects - How to Remove Ethanol: #2905245
04/02/21 09:34 AM
04/02/21 09:34 AM
Highland, MI.
Sunroofcuda Offline OP
Highland, MI.
I was checking out a few videos last night & these three stood out:
https://youtu.be/UvS_D4_lF5U (seeing the effects)
https://youtu.be/HdDEL7WLN5U (removing)
https://youtu.be/RO1hsaxaMXo (removing)
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: Sunroofcuda] #2905301
04/02/21 11:12 AM
04/02/21 11:12 AM
moparx Offline
moparx  Offline
thanks for sharing those ! bow
now i'm going to try it !
beer
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: moparx] #2905314
04/02/21 11:26 AM
04/02/21 11:26 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
That guy has a voice as annoying as ANY Infomercial announcer.
Fran Drescher would be an even swap for that guy.
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: moparx] #2905317
04/02/21 11:28 AM
04/02/21 11:28 AM
Highland, MI.
Highland, MI.
I think it's a great idea to add a little food coloring to the water if you are going to separate the ethanol from the fuel. I am quite fortunate in that I have 3 gas stations nearby that sell the rec fuel. I run nothing but the ethanol-free fuel in all my power equipment, my Merc-powered bass boat, & my 2016 Scat Pack Challenger. About 6 years ago (before I started using the rec fuel), my boat engine would barely start & run the first time each season. Now I see why. I also used to have major issues with my push lawnmower to the point I had to take it to a small engine repair shop for them to go through the carb to get it running one year. The ethanol combined with a really crappy carburetor on it that is............
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: Sunroofcuda] #2905337
04/02/21 12:02 PM
04/02/21 12:02 PM
Buckeye Lake
56_Royal_Lancer Offline
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Two years ago I started running Rec gas exclusively in my '69 Buick. The change in drivability, start up after storage, etc is amazing.
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: 56_Royal_Lancer] #2905352
04/02/21 12:31 PM
04/02/21 12:31 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
You can buy treatments
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: SRT6776] #2905423
04/02/21 03:21 PM
04/02/21 03:21 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
taking the ethanol out reduces octane rating quite a bit.
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: HotRodDave] #2905593
04/02/21 09:35 PM
04/02/21 09:35 PM
IMGTX Offline
IMGTX  Offline
True, these guys said they started with Premium because the octane was reduced.
Around here Premium costs more than non-ethanol. Kind of a wash.
Still great information I will remember.
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: IMGTX] #2905606
04/02/21 10:15 PM
04/02/21 10:15 PM
Highland, MI.
Highland, MI.
All the rec fuel around me is marked 90 octane. The Challenger shows no ill effects from 90 octane at all.
Here's where you find rec fuels in your areas - pick your state: www.pure-gas.org
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: Sunroofcuda] #2905968
04/03/21 10:50 PM
04/03/21 10:50 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
runaway runaway runaway
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: GoodysGotaCuda] #2907028
04/05/21 09:24 PM
04/05/21 09:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Anytime I come accross e-85 I put it in whatever car I am driving, only one time had an issue, my 97 neon ran like crap for about the first 100 miles than cleared up and ran great the rest of the tank.
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: HotRodDave] #2907071
04/05/21 11:23 PM
04/05/21 11:23 PM
Highland, MI.
Highland, MI.
Why would ANYBODY want to run E-85???
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: Sunroofcuda] #2907099
04/06/21 12:21 AM
04/06/21 12:21 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Quite a few turbocharged cars run it. Lots cheaper than race gas, and available all over the Midwest.
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: John Brown] #2907134
04/06/21 07:23 AM
04/06/21 07:23 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
It supports running higher compression engines. I have read you came run 14-15 to 1 compression using E85 without knocking issues.
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: Sunroofcuda] #2907138
04/06/21 07:41 AM
04/06/21 07:41 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
The turbo guys run it and make big power with it.
It resists detonation and is like cheap race gas to them.
It's not uncommon to pick up big HP gains going to E-85 from pump gas because they can run more timing and boost!
'63 Dodge 330
11.19 @ 121 mph
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: Sunroofcuda] #2907201
04/06/21 10:41 AM
04/06/21 10:41 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I was looking at an Eagle that had a blown 383 in it. I would have run E85 in that if the deal worked out.
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: Sunroofcuda] #2907302
04/06/21 01:34 PM
04/06/21 01:34 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Its much cheaper, supports very high compression (actually enough to offset most if not all efficiency loss VS pump gas), and if your car is NOT a "flex fuel" vehicle the computer will not richen the mix up enough to hurt MPG, Less carbon build up in combustion chambers, smells like pop corn, supports american farmers instead of saudi terrorists, helps engine run cooler, can make more HP because it carries more oxygen into the air fuel mixture... heck the only good reason I see to not to is because al gore likes it.
I put a bunch of fuel system parts (steel lines, t-quad float bowl pieces, aluminum, brass, 68 cuda fuel hose...) in a sealed jar of e-85 and now 15 years later it all looks the same as when I put it in so I don't buy that the ethanol is what is plugging stuff up, ethanol actually leaves zero residue when it evaporates. If you keep the moisture out (don't put it in a boat or something with an atmosphere vented cap that will sit a long time) it will not corrode anything up,.
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: Kern Dog] #2907305
04/06/21 01:44 PM
04/06/21 01:44 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
The guy doing the video showing the effects of ethanol...sounds just like Krusty the clown.......... work
Plymouth Makes It!
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: RoadRunnerLuva] #2907310
04/06/21 01:51 PM
04/06/21 01:51 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Krusty was voiced by Kelsey Grammer. I haven't seen the Simpsons in years!
Re: Fuel With Ethanol Effects - How to Remove Ethanol: [Re: Kern Dog] #2907353
04/06/21 03:28 PM
04/06/21 03:28 PM
Buckeye Lake
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
I thought it was Sideshow Bob
