Re: Leaf spring metal bushing sleeve
[Re: jcc]
#2906847
04/05/21 11:45 AM
04/05/21 11:45 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Use a hot wrench on the inner sleeve. It will melt the rubber then you can push the sleeve and rubber out leaving the outer.
Carl Kessel
[Re: CKessel]
#2906987
04/05/21 07:50 PM
04/05/21 07:50 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
Long bolt with a large washer (that is smaller than the diameter of the bushing) on one side with a large socket on the other with a piece of flat stock and a nut. Tighten the nut and draw the bushing through into the socket. Not a very good description, but I used this setup to replace a set of spring bushings when doing a Cal-Track install.
