Re: Fuel With Ethanol Effects - How to Remove Ethanol:
[Re: moparx]
#2905317
04/02/21 11:28 AM
04/02/21 11:28 AM
Posts: 8,392 Highland, MI.
Sunroofcuda
Highland, MI.
I think it's a great idea to add a little food coloring to the water if you are going to separate the ethanol from the fuel. I am quite fortunate in that I have 3 gas stations nearby that sell the rec fuel. I run nothing but the ethanol-free fuel in all my power equipment, my Merc-powered bass boat, & my 2016 Scat Pack Challenger. About 6 years ago (before I started using the rec fuel), my boat engine would barely start & run the first time each season. Now I see why. I also used to have major issues with my push lawnmower to the point I had to take it to a small engine repair shop for them to go through the carb to get it running one year. The ethanol combined with a really crappy carburetor on it that is............
[Re: 56_Royal_Lancer]
#2905352
04/02/21 12:31 PM
04/02/21 12:31 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
[Re: SRT6776]
#2905423
04/02/21 03:21 PM
04/02/21 03:21 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
taking the ethanol out reduces octane rating quite a bit.
[Re: IMGTX]
#2905606
04/02/21 10:15 PM
04/02/21 10:15 PM
Sunroofcuda
Highland, MI.
All the rec fuel around me is marked 90 octane. The Challenger shows no ill effects from 90 octane at all. Here's where you find rec fuels in your areas - pick your state: www.pure-gas.org
[Re: Sunroofcuda]
#2905968
04/03/21 10:50 PM
04/03/21 10:50 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
[Re: GoodysGotaCuda]
#2907028
04/05/21 09:24 PM
04/05/21 09:24 PM
HotRodDave
Kalispell Mt.
Anytime I come accross e-85 I put it in whatever car I am driving, only one time had an issue, my 97 neon ran like crap for about the first 100 miles than cleared up and ran great the rest of the tank.
[Re: HotRodDave]
#2907071
04/05/21 11:23 PM
04/05/21 11:23 PM
Sunroofcuda
Highland, MI.
Why would ANYBODY want to run E-85???
[Re: Sunroofcuda]
#2907099
04/06/21 12:21 AM
04/06/21 12:21 AM
Posts: 1,819 South Bend
John Brown
South Bend
Why would ANYBODY want to run E-85??? Quite a few turbocharged cars run it. Lots cheaper than race gas, and available all over the Midwest.
[Re: Sunroofcuda]
#2907138
04/06/21 07:41 AM
04/06/21 07:41 AM
Posts: 4,663 Wichita
GY3
Wichita
Why would ANYBODY want to run E-85??? The turbo guys run it and make big power with it. It resists detonation and is like cheap race gas to them. It's not uncommon to pick up big HP gains going to E-85 from pump gas because they can run more timing and boost!
[Re: Sunroofcuda]
#2907201
04/06/21 10:41 AM
04/06/21 10:41 AM
Posts: 6,220 nowhere
Sniper
nowhere
Why would ANYBODY want to run E-85??? I was looking at an Eagle that had a blown 383 in it. I would have run E85 in that if the deal worked out.
[Re: Sunroofcuda]
#2907302
04/06/21 01:34 PM
04/06/21 01:34 PM
HotRodDave
Kalispell Mt.
Why would ANYBODY want to run E-85??? Its much cheaper, supports very high compression (actually enough to offset most if not all efficiency loss VS pump gas), and if your car is NOT a "flex fuel" vehicle the computer will not richen the mix up enough to hurt MPG, Less carbon build up in combustion chambers, smells like pop corn, supports american farmers instead of saudi terrorists, helps engine run cooler, can make more HP because it carries more oxygen into the air fuel mixture... heck the only good reason I see to not to is because al gore likes it. I put a bunch of fuel system parts (steel lines, t-quad float bowl pieces, aluminum, brass, 68 cuda fuel hose...) in a sealed jar of e-85 and now 15 years later it all looks the same as when I put it in so I don't buy that the ethanol is what is plugging stuff up, ethanol actually leaves zero residue when it evaporates. If you keep the moisture out (don't put it in a boat or something with an atmosphere vented cap that will sit a long time) it will not corrode anything up,.
[Re: Kern Dog]
#2907305
04/06/21 01:44 PM
04/06/21 01:44 PM
Posts: 5,304 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
That guy has a voice as annoying as ANY Infomercial announcer. Fran Drescher would be an even swap for that guy. The guy doing the video showing the effects of ethanol...sounds just like Krusty the clown..........
Plymouth Makes It!
