Ferrule fitting question #2903741
03/28/21 07:22 PM
03/28/21 07:22 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I want to make a stainless fuel line.My question is can I use an AN ferrule fitting? 3/8 if that matters.
Thanks in advance
Re: Ferrule fitting question [Re: 5carguy] #2903753
03/28/21 07:49 PM
03/28/21 07:49 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The AN fitting system by definition is a flare style fitting, not a ferrule style. Just what are you trying, exactly, to do?
Re: Ferrule fitting question [Re: 6PakBee] #2903792
03/28/21 09:11 PM
03/28/21 09:11 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I want to make a fuel line with 3/8 stainless tube and I have some #6 AN ferrule fittings.Also I would like to use an electric fuel pump.
Re: Ferrule fitting question [Re: 5carguy] #2904008
03/29/21 01:46 PM
03/29/21 01:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Better known as a compression fitting. Here's what Earl"s says:
Re: Ferrule fitting question [Re: John_Kunkel] #2904100
03/29/21 09:04 PM
03/29/21 09:04 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Just make sure the ferrule fittings you're going to use are for stainless steel tubing. I had an awful time getting stainless steel fittings to stay sealed when I ran new lines on my efi Dakota, I ended up running all new plastic Fuel Injection lines.
Re: Ferrule fitting question [Re: poorboy] #2905386
04/02/21 01:47 PM
04/02/21 01:47 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
If you are flaring the "ferrule" or sleeve is immaterial and they are interchangeable. More important is the tubing. Do not use seamless stainless tubing
for flaring. If you look down the barrel of your tubing and the inside diameter is not centered in the tubing it is seamless and will not flare properly and it will leak.
Welded and drawn stainless tubing is not easy to find these days.
If you are using a compression style fitting welded and drawn tubing and seamless are interchangeable.
Re: Ferrule fitting question [Re: BIGGERED] #2905842
04/03/21 02:20 PM
04/03/21 02:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The use of the word "ferrule" can be confusing, technically the fitting that the OP refers to is a compression fitting (bottom pic) where a ferrule is a sleeve used with flared tubing and a flare nut. (top pic)
Re: Ferrule fitting question [Re: John_Kunkel] #2938861
07/01/21 09:31 PM
07/01/21 09:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
There is also the Swagelok type fittings that are pricey but nice. They are available in a number of different materials, Won't leak, no flaring required, and are infinitely reusable if not abused.
I happen to have a bunch of SS ones on hand depending on what sizes etc. you might need. You can find their catalog online and get lost in there LOL beer
Re: Ferrule fitting question [Re: TJP] #2959690
08/31/21 08:46 PM
08/31/21 08:46 PM
napa ca
P
procharged 484 Offline
P
napa ca
SWAGELOK the best , the juice is worth the squeeze
