Fatman front suspension in a Sweptline #2905473
04/02/21 05:03 PM
04/02/21 05:03 PM
WInter Park, FL
V
Volksnut Offline OP
Volksnut  Offline OP
V
WInter Park, FL
I'm about to pull the trigger on a Fatman Mustang II for my '63. Anyone here do the swap and how did it go. I definitely want the power steering and it will be coils can't afford the coil overs, also can you still use your front engine mounts, want to install a big block...I'm assuming rear sump pan? Thanks
Re: Fatman front suspension in a Sweptline [Re: Volksnut] #2905553
04/02/21 07:56 PM
04/02/21 07:56 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
We just swapped a 73-93 Dodge pickup frame under the 70 Sweptline sheet metal the last time we did one. If its a short box, everything pretty much bolted together. I think we had to trim the top 1" off the frame hump over the rear axle and replace it with a flat 1/8" x 2" bar stock. I really think every thing else just bolted into place, but its been 15 years ago.
6 months later when we swapped the small block for a big block without any factory parts, we ran into a few challenges, but the cab to frame was pretty straight forward. Gene
